Sponsored by: CARiD
First Generation Question-Transmissions.
Old Jul 20, 2004 | 05:09 PM
White 87 13B's Avatar
Hey, my friend just recently aquired a 1983 Rx7 GSL. The car is in damn good shape everywhere but the Transmission. There is a heavy ratchetting noise and it is lacking power. He has a 1979 LM Rx7 with a good transmission. I found that the rear end of the transmission and the shift lever are set up differently...Could someone help me figure out how to make this work?! I need serious help before Sunday the 25th.
Old Jul 20, 2004 | 07:04 PM
Project84's Avatar
Open up! Search Warrant!
http://members.ij.net/mrmazda/interc...html#TRANUSAGE
This says you would have to swap the tail housing and shift mechanism from the '83 transmission to the earlier transmission. (As long as they are both 5 speed gearboxes)
That works for 1980 transmission, not 100% sure about 1979 because it doesn't specifically say '79, it says late '80. Its not hard to unbolt a tail housing, I took one off the tranny in my garage. The bolts are a little tight, but don't use extra muscle, they are long and skinny bolts and could break easily if they are corroded.
Old Jul 20, 2004 | 10:41 PM
peejay's Avatar
Old [Sch|F]ool
It only works for SA's of VIN number 606775 and later are an easy swap, as noted on my page http://www.geocities.com/izzmus/trans/trans.html. 606775 was in March or April of 1980, forget which. Last few months of '80 production, anyway.
Earlier trannies *might* be useable, *if* you also swap out the shift rods, possibly the shift forks.
