vacuum question
Old Jul 18, 2004 | 09:11 PM
TurboII2NV's Avatar
vacuum question
is it possible to get rid of the vacuum nest below the upper intake on a TII
and just connect the fuel delivery and return directly to the fuel rail?? and just toss that stupid nest in the garbage?
Old Jul 18, 2004 | 09:25 PM
Project84's Avatar
Open up! Search Warrant!
For a 86-88 TII, this is what you need to do.
Old Jul 18, 2004 | 09:49 PM
miketreid's Avatar
Do you have one of those for a N/A?
Old Jul 18, 2004 | 09:54 PM
red_ricer's Avatar
Spending too much $$$
A little off the subject but if you remove the air bypass valve when you make a TID and block the BAC off where do you run the boost sensor from?
Old Jul 18, 2004 | 10:30 PM
VietFC's Avatar
from the same spot. The BAC is above the boost sensor nipple.
Old Jul 18, 2004 | 11:13 PM
TurboII2NV's Avatar
thanks guys this helps a lot
it will be done
Old Jul 18, 2004 | 11:14 PM
red_ricer's Avatar
Oh.....ok cool
Old Jul 19, 2004 | 01:05 PM
baddassTurboII's Avatar
Where do the oil injector air bleeds go?
Old Jul 21, 2004 | 10:46 AM
Can you guys tell me where the injector bleeds and oil bleeds go? I have no clue,from the picture I cannot tell which hose goes where,also on the side where it say caps with the red arrow is ? do you cap all three lines? and last question, whats a restrictor pill?
_Tones_
May 25, 2021 05:37 AM
ZacMan
Sep 19, 2015 09:20 PM
Nosferatu
Sep 5, 2015 02:13 PM
Frisky Arab
Sep 4, 2015 06:17 PM
