Getting gas cartridge out of shock housing
Old Nov 16, 2001 | 06:50 AM
ScruffyChimp's Avatar
Hi.
I'm putting KYB cartidges in my front shocks. I've taken a shock off the car and removed the spring, but I can't work out how to get the old cartridge out.
There is a metal ring with a small dip at 12 o'clock and 6 o'clock. I can't get this out. Can anyone offer any advice? Haynes says you can cut a steel pipe, but that sounds like a lot of work. Is there an easier way? I can't make it budge with pliers.
Can any of you explain the process you went through to replace your shocks?
Thanks,
ScruffyChimp
Old Nov 16, 2001 | 06:52 AM
Node's Avatar
very nice name
Old Nov 16, 2001 | 02:32 PM
yayarx7's Avatar
Are you Nucking Futs?
If I remember correctly there is a big nut holding the cartrage in the body. I just stuck the body in a vice and cranked on the nut with a big (4 foot) wrench.
Hope this helps.
matty
Jan 18, 2020 10:39 AM
R7rexy
19
Sep 2, 2015 10:24 AM
82streetracer
Aug 23, 2015 09:28 AM
