Turbo II have an external amp??
Old Nov 15, 2001 | 09:18 PM
Rx-7Addict's Avatar
Rotary Powered
Does it?
I was just wondering.
I have an 88 T2 with the factory double-DIN clairon deck. I was wondering because I went to hook up my stereo ( I hadnt done it before and my friends were over to help me) and it worked fine, but no sound.
I hope it doesnt, but I think it does. Also, if is does, where is it at? I had my friend look at it and he thought it did have an external amp and he looked for it and thought he found it under the drivers side dash.. anyone know? Thanks in advance
Old Nov 16, 2001 | 07:15 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Yeah the 3 different locations for factory amps are drivers dash behind front speaker (usually is the Pioneer stereo one tho), inside the right front speaker enclosure (if applicable). And in the vert behind the drivers seat in the spare tire cover for the headrest speakers.
The left side dash one is usually for door speakers if you have 'em. The right side one usually drives the front speakers.
By the way unless you know exactly what you are doing, Have a true professional do it, cuz when you dont know what your doing and you get in there and screw it up and want a pro to fix it. They will charge you more to do it right and fix what was messed up. Or at least I would, have to justify the extra time...
Old Nov 16, 2001 | 07:41 PM
vaughnc's Avatar
knowledge junkie
In my 1992 there was an external OEM amp under the passengers side dash. I just plugged the cables together bypassing the AMP and it worked fine. If you have 6 speakers (rear, door, dash) you'll need to use an external amp as the radio only has 4 speaker outputs.
Old Nov 16, 2001 | 09:16 PM
Rx-7Addict's Avatar
Rotary Powered
Unhappy ahh
1992?
Well, I have the 2 dash speakers and the 2 in the shock towers.
I guess I need a relay or something to disable the external amp. My stereo powers on fine its just theres no sound.
How hard is it to wire this in and bypass that amp.
Can I just take the amp out totally if I am going to bypass it?
(every little pound counts)
Also, where is this amp? I think its under the drivers side dash.
I went to circuit city and they said that the amps are under the storage bins and they wanted to charge close to $100 to rip apart the carpet and all that crap. Someone please help
Old Nov 16, 2001 | 10:47 PM
vaughnc's Avatar
knowledge junkie
Easy way to tell - compare the wire colors behind the radio to the speaker location wire colors. If they match, then no in-line external amp.
I'm assuming your using a wiring harness adapter and not splicing the wiring harness? If not get some from crutchfield.com.
Another trick is to de-sauder the OEM speakers harness adapters and sauder those to the new speakers wire connector.
Bypassing the amp is easy (assuming you have one). It has 2 plus that connect to it. Just unplug both of them and plug them together. Remove the amp and your done.
Old Nov 18, 2001 | 02:28 PM
Rx-7Addict's Avatar
Rotary Powered
Thanks, vaughnc. Does anyone know where the external amp(s) are in my car? I have everything working but no sound to the speakers because of the amps. If someone knows where they are located that would help a bunch. If it really is as easy and plugging 2 wires together that would be awesome. Thanks
Old Nov 18, 2001 | 11:08 PM
MIKE-P-28's Avatar
Dunno abou Circuit City, 100? is high. I do any car with factory amps, for the normal free install with a purchase of a deck from us + 15-25 extra, unless its a 7 series BMX, Mercedes Benx, or Lexus.
The Shaolin
Sep 14, 2015 07:50 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
