parts for 13b-re
Old Jul 12, 2004 | 05:41 PM
RotaryExperimental's Avatar
parts for 13b-re
What is the best place to find replacement parts, like gaskets and misc. stuff.?
Also do any of the parts from the 13b-rew interchangable with the 13b-re?
Old Jul 18, 2004 | 10:37 PM
bump, anyone?
Old Jul 21, 2004 | 12:58 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
re-rew comparisons...
the rotora are the same from what i understand, along with the rotor housings, e-shaft, and some other do-dads..
the irons are swappable if you do them in sets--the re's have bigger ports, so if you use one iron, you have to use them all, but they're compatible as a whole.
mazdatrix is about the most convenient place to get stuff like that...maybe racing beat also. the dealer is usually a bit cheaper, but they take forever getting the stuff and usually won't ship
Old Jul 21, 2004 | 05:45 PM
thanks for the info man. Any one got any other sources?
Old Jul 26, 2004 | 07:09 PM
doridori-rx7's Avatar
Navy MarCom
no sources, but a few things I've found from my RE -FC build up - the RWS S5 II rebuild kit fits the ticket( minus the intake gaskets ). use an S4 mechanical OMP, S5 oilpan. you can use the S5 ECU as long as you switch the CAS to a S5 CAS. the Oil cooler lines need to be modified, block off the rear turbo oil return, make an adaptor for the TII tranny so the starter will have someplace to bolt to, FC3S.org has RE-FC engine mounts... bunch of other stuff but that's the bulk of what little I've been able to garner from here and a few other places..
Old Jul 26, 2004 | 08:02 PM
I dont plan on using a omp at all, i plan on premixing.
What are you talking about with using the s5 oil pan? is it because the re pan has 2 oil returns in it?
I plan on running a e6x so i dont need to worry about the s5 ecu.
Old Jul 26, 2004 | 09:49 PM
Also does any one know what block off plate to use for the RE? Should i use s5 or 13b-rew?
Old Jul 27, 2004 | 02:46 AM
Navy MarCom
I use the E6X myself, I use the TII oilpan becuse the RE one does not clear the subframe properly also the TII allows me to refabricate it to hold more oil and to baffle it allot cheaper then going to a dry setup..
I personally avoid premix as the mixture only hits the FACE of the rotor and very little actually makes it to where it's suppose to be and doing the most good, being swept by the apex seal.
as for block off plates, a few from both kits will work but allot of them that sit on the intake manifold will need to be fabricated by someone, I made my own.
Old Jul 27, 2004 | 01:01 PM
Rx_treme's Avatar
im using the e6k and im runnin pre mix, and made most all of my own block off plates and gaskets myself.
I did also use the RE oil pan. worked fine with no clearance issues for me.
Doridori, do you have any pics of your modded T2 oil pan??
Old Jul 27, 2004 | 01:30 PM
TonyTurboII's Avatar
Glock Lover
The -RE oil pan will work fine , assuming your using K2RD or FC3S mounts.
Block off plates can also be bought for the -RE from K2RD.
The pan has nothing to do with the oil returns, the front one is built into the front cover, and the rear one is built into one of the rear housings.
Use the front one, and the rear one can be blocked off with a -REW rear oil drain block off plate.
Old Jul 27, 2004 | 01:52 PM
Navy MarCom
I am using my own design engine mounts for strength, however it's good to know that somone has parts for the RE...
I
ll see if I can find a pic or two, I may have taken some while I saw fabricating it up
Old Jul 27, 2004 | 04:44 PM
Thanks for all the info guys.
Old Jul 30, 2004 | 03:42 PM
cymfc3s's Avatar
I Raise Chickens
I have a couple extra 13B-RE ACV block off plates that i had cut for my car. Send me a PM is need one.
Old Jul 31, 2004 | 09:04 AM
Turbo1's Avatar
Dude.... call Shane at Rotaryworks in Jax. Met, talked with, hung out with, bought a few things....seems to be a stand-up guy. He had like 3 RE motors there
PM me for his phone number if you want it.
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
