Is there a thread on how to strip an FC for racing???
Old Jul 10, 2004 | 09:22 PM
Couldn't find it in search.....Thanks.
BBZ
Old Jul 12, 2004 | 07:28 AM
Travis R's Avatar
trying to build a racecar
There should be, it's been covered before.
But here's the basic summary.
Step 1: Unbolt/remove everything you don't need
Step 2: Go racing
Old Jul 12, 2004 | 08:06 AM
RETed's Avatar
Take it to a shop that can do this properly.
-Ted
Old Jul 12, 2004 | 02:17 PM
MPM's Avatar
MPM
As insightful as ever reted. Atleast Travis put a smiley face on his.
blackbirdzach - What class or type of racing to you want to do? autocross, road racing, drag........... I'm assuming autocross and track events listed on your profile. If autocross, what class do you want to run?
Old Jul 12, 2004 | 03:04 PM
TrentO's Avatar
For a serious Road race build I did the following:
-3 days of stripping the car down to a bare shell ( by bare I mean no two bolts were still together)
-A trip to the Acid tank for a double dip (Cost about $700). The acid strip takes the car to bare metal and offers a really good chance to see exactly what you have. Any body damage will be very obvious.
-3 Days of seam welding. This isn't really required, but if you want the stiffest car you can get I'd reccomend it.
-3 Days of Roll cage fabrication. The design and material of the roll cage depends on the sanctioning body you plan on racing in, but three days with two people, a tubing bender and a mig welder should do the trick.
-XX days of reassembly. I'm still in this part, so I'd budget at least 10-15 working days to reassemble the car. The less custom work you do at this point the faster the assembly will go.
- At least one day of testing / tuning before you go to an event
-At least one evening following the test day to re-check every fastener on the car.
Hope this helps,
-Trent
Old Jul 12, 2004 | 10:49 PM
RETed's Avatar
It's not as easy as it sounds, and you have to know a little about structural engineering to understand what is okay and what is downright dangerous.
I'm assuming the person is a typical owner who does not know that much about their cars.
There is a right way and a wrong way to do lightening, and doing it the wrong way can kill you on the street or on the track.
-Ted
Old Jul 13, 2004 | 09:21 AM
Travis R's Avatar
Maybe BBZ will chime back in and let us know some details about what kind of racing and his experience.
Old Jul 13, 2004 | 11:01 AM
Well, my biggest conern is how to get the sound material out from under the carpet! And I also want to remove the door panels and take out the power window regs, and replace them with manuals. I don't want any electrics in the doors.
I've got most of the A/C already out and the carpets are almost done....still gotta remove the pass seat. I just haven't really had time to do it all.
The car will mostly be autocrossed with a couple of track days a year. But I'll also be driving it back and forth to work on occasion.
Oh, and any of you ever removed your headliner? I've got to do that to remove the sunroof. (Frozen up)
Thanks,
BBZ
Old Jul 13, 2004 | 11:54 AM
Re-Speed.com's Avatar
Do you have a rule book? If you go stripping stuff it will move you into a class step up. This next class may allow modifications that could leave you non competitive.
The Sound material is removed with Dry Ice. You can buy it at publix. Sit it on a spot. Let it sit for a few minutes, move it to the next spot. Start hitting the first spot with a rubber hammer and 1" or so wide chisel or scraper.You can wipe the surfaces down with Acetone or paint thinner to get it ready for paint.
-billy
Old Jul 13, 2004 | 12:10 PM
-billy
Dry Ice, eh? I'll give it a try. Thanks Billy!
BBZ
Old Jul 13, 2004 | 01:41 PM
Travis R's Avatar
I used an air chisel on a cold winter day.
Old Jul 13, 2004 | 02:53 PM
RX-Heven's Avatar
I'll blow it up real good
By far the easiest and quickest way to do this. But considering it's the middle of summer, dry ice is the next best thing. Be careful with the air chisel though or you can go right through the floor. Some 'huffers' use diesel fuel to soften it up and scrape it out....yuck.
Old Jul 13, 2004 | 03:12 PM
Epp! I'll get some dry ice on Friday and start on it on Saturday.
Old Jul 14, 2004 | 11:54 AM
speeddemon32's Avatar
No more 7 or 8
i have never tried the dry ice thing, we used a torch and a scraper. it worked really well...... with the exception of the smell!
i also took the car down to bare frame, it think this is the best way to start a major tack car project.
take a look at my web site if you want to see some of the building process.
http://groups.msn.com/ROTORLUTIONRacing
Old Jul 15, 2004 | 03:17 AM
SPiN Racing's Avatar
Here is a thread with questions on lightening a Vert.. many will apply to you.
https://www.rx7club.com/showthread.p...ght=lightening
Kinda just need to decide how far you wanna go
Old Jul 18, 2004 | 12:26 PM
wrankin's Avatar
Old Rotary Dog
You can also follow Crispy's exploits in building his FC racecar.
http://www.negative-camber.org/crispyrx7/fc/fcpart1.htm
-bill
Old Jul 21, 2004 | 10:41 AM
GlitchFC's Avatar
http://www.nissaninfiniticlub.net/ph...cat=500&page=1
me and my buddies' FC as we tear it down.
Th0m4s
Feb 26, 2019 02:04 AM
turbo-minivan
69
Feb 4, 2016 12:29 AM
sYnth.
Aug 19, 2015 06:27 PM
