Steering Wheel Hub w/wiring harness
Old Nov 15, 2001 | 01:52 PM
Chadwick's Avatar
Mr Sparkles
Thumbs up Steering Wheel Hub w/wiring harness
Not sure if anyone has been looking for a Hub adapter with the Airbag defeater like I have, but I have found a source for them.
Most of the Mazda shops carried Mazda Speed hubs that did the job, but when Mazda took them over, the supply in the states dried up. Mazda Speed will no longer import them into the US and dealers like Corksports had run out months ago.
I found a place that can get them for $124.95. Link below for you to contact him. Guy I talked to was named Tom. He said that if I knew anyone else that wanted one to have them contact him before monday so they can go on the same order to get them faster.
Finish Line Performance
Note: You will have to call him as they are not listed on the site for the Rx-7, but they will look just like the one used on the Miata.
Hope this helps,
Dan
Old Nov 15, 2001 | 04:33 PM
rx7even's Avatar
Smile
Awesome thanks! I may have to order this tomorrow!
Old Nov 15, 2001 | 06:36 PM
JoeD's Avatar
what exactly is the use of this?? cant you just un-hook the wiring for the air bag??
Old Nov 15, 2001 | 08:26 PM
JoeD's Avatar
Old Nov 15, 2001 | 08:28 PM
the_glass_man's Avatar
Will u do me a kindness?
Not, without getting the dummy light to come on. This tricks the ABS computer into thinking its there and you won't have to worry about the light. I think thats about right.
Old Nov 15, 2001 | 08:31 PM
JoeD's Avatar
then you can just remove the light bulb. no more idiot light!
Old Nov 15, 2001 | 08:36 PM
Yeah thats the ghetto way!
But its cheaper too!
Old Nov 15, 2001 | 08:55 PM
JoeD's Avatar
nothin wrong with ghetto. :p
Old Nov 15, 2001 | 10:47 PM
rx7speed811's Avatar
Accepting Donations.
im down to get paid $125 to be ghetto...
Old Nov 15, 2001 | 11:26 PM
Chadwick's Avatar
Mr Sparkles
Have you tried to get to the light to unplug it? Also, this has a factor plug in for the horn, so no splicing of wires. Some like to jerry rig, I prefer to spend a few bucks and never have to worry about it again.
By the way, you can defeat the light with a 3 Ohm resistor and not worry about unplugging it.
Hope this helps,
Dan
Snoopy FD
Dec 8, 2015 01:45 PM
