Injector size?
Old Jul 7, 2004 | 07:26 AM
rotary632's Avatar
Injector size?
How could I find out what the injector size is for the 85 SE? Or for that matter any on the later rx7's? Is there a manual or spec book? thnx
Old Jul 7, 2004 | 07:30 AM
LongDuck's Avatar
84SE-EGI helpy-helperton
Mazda FSM for 84/85 SE's lists these as 'orange top' (plastic insulator color), 680cc nominal flow at standard pressure out of a good pump. Low impedence injectors are used in the SE models.
The later model, Gen 2 cars use staged injectors of 550cc flow, primary, plus 2 720cc flow injectors for secondaries. I believe these to be high impedence, which was a change in the Gen 2 EFI system.
Someone please correct me if I've remembered this incorrectly. HTH,
Old Jul 7, 2004 | 09:36 AM
fatboy7's Avatar
Got Boost?
Only the TII models came with the 550's, and they used 550's all around. 720's are a popular upgrade though.
Old Jul 7, 2004 | 09:46 AM
SS124A's Avatar
0000-09-0233
I like my 1600's...
Old Jul 7, 2004 | 10:07 PM
RotaryRevn's Avatar
I had my 85 gslse injectors cleaned and tested at RC engineering, they flowed 720. I believe 85 is 720, 84 680
Old Jul 8, 2004 | 11:24 PM
steve84GS TII's Avatar
FB+FC=F-ME
12AT (2) 800cc injectors low impedence
84-85 GSL-SE (2) 680cc injectors low impedence
86-91 N/A (4) 460cc injectors,same impedence change as TII
87-87.5 TII (4) 550cc injectors low impedence
87.5-91 TII (4) 550cc injectors high impedence
Old Jul 8, 2004 | 11:28 PM
Max7's Avatar
Admitted Sevenaholic
I had 2 85's flo 720'ish and my 84 680'ish when R/C cleaned them, maybe they upped the fuel flow in the 85's.
Old Jul 9, 2004 | 12:51 AM
RotaryRevn's Avatar
Yup, everyone I know that has had 85's tested flowed 720 give or take.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
