What coils for 13BT and 4ch CDI
Old Jul 4, 2004 | 09:28 AM
frode's Avatar
Hi,
What coils should I use on my 13BT? Engine will sit in a 1st gen RX-7, controlled by Autronic SM2 and coils will be fired from a Autronic 500R 4 channel CDI. At the moment I have a set of stock 2nd gen coils, not sure on how they will work with the CDI.
I've heard good things about Crane LX92..
I can get Bosch coils designed for CDI use from the local dealer (they will cost about the same as 4 LX92's).
What would be optimal, 2 single ended and one double ended (like the stock setup) or 4 single ended units?
Any input?
Regards,
Frode
Old Jul 4, 2004 | 04:18 PM
rxseven's Avatar
Special Dark
Well, since you brought it up let me tell you what i just went through. I have an msd 6a cdi used in the direct fire set-up with fc leading coil pack. Like many other people on this forum, there was not a spectacular performance increase and some say it is not worth it. I also noticed my spark plugs get black with carbon even though my a/f ratio is not very rich. I happen to come across the Nology Profire dual output CDI coil and it made a noticeable difference. It is a little pricey at $90 but the spark plugs stay in better shape from what I can tell so far and idles better. Not exactly sure what the difference is between a CDI coil and regular stock one. Anyone care to explain?
Old Jul 5, 2004 | 08:19 AM
RICE RACING's Avatar
LX92 all the way !
I am running 4 of these on my R500 and SM2 !
I had two LX92's and two crane CDI's on my old set up and they ROCKED !. Great coil and very cheap.
I will ahve my new set up running very soon and am sure it will more than handle what I want it to do.......
Old Jul 5, 2004 | 03:27 PM
rxseven's Avatar
Special Dark
Any one know of some brands that make a dual output cdi coil?
rotor_veux
Sep 28, 2015 09:25 PM
GKW
Sep 28, 2015 04:34 PM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
