Flushing Coolant
Old Nov 14, 2001 | 01:44 AM
Flushing Coolant
I wanna check before i finally do it....how does everyone flush their coolant and replace with fresh stuff for the winter.
the drain plug is a bitch to get to
thanks, Mike
87 Turbo2
Old Nov 14, 2001 | 02:16 PM
Evil Aviator's Avatar
Rotorhead
See "Cooling System" chapter:
http://www.iluvmyrx7.com/Technical_I...ice_manual.htm
Old Nov 14, 2001 | 02:27 PM
dwillms's Avatar
The collant flush plug is easy to get at. Just remove the black plastic shielding from under your engine bay and you will have direct acess to the plug, its in the middle at the bottom of the radiator.
-Daryl
Old Nov 14, 2001 | 05:04 PM
the link didnt work.....id like to check it out
Mike
Old Nov 14, 2001 | 05:15 PM
Champagne87's Avatar
Dangerous Curves
Daryl, your right about the drain plug under the radiator, but you don't need to remove the sheilding, there is a hole which is directly under the plug. and there is another plug that is to drain the engine. It is under the engine obviously, the plug is in between the bolts for the engine mount on the driver side.
Do a search or maybe someone else will have the link to some pics for it.
-Jessica
Old Nov 15, 2001 | 01:47 AM
Rotorhead
Mike
That's strange, it works when I click on it.
Maybe if you try the parent directory?
Old Nov 15, 2001 | 01:33 PM
How much coolant?
When we flush and fill our cooling systems how much of the new mixture does it take? I now many people use different mixutres of water/coolant/additives sometimes) anyone found a particualarly good one?
LongDuck
Oct 7, 2015 08:12 PM
musker
Oct 1, 2015 05:58 PM
