More fuel?
Old Nov 14, 2001 | 12:00 AM
RestoTII's Avatar
More fuel?
Alright guys, it's the holidays, so I figure I'll treat myself (and the rex) to some goodies.... I was thinking about upgrading some fuel components, but I'm not too sure what I should do. Here's my mods.
1987 TII
3" RB turbo back exhaust with presilencers and no cats
FCD
Without an intake, I figure I probably don't really need the extra fuel right now, but it's nice to know that I have a fighting chance if I decide to get an intake and/or port the throttle body. so should I even bother adding fuel now, and if so, just a pump w/rewire, or should I look into upgrading/adding injectors? Thanks guys
Old Nov 14, 2001 | 12:34 AM
Scott 89t2's Avatar
SOLD THE RX-7!
umm, you probably need the fuel now. do you have a boost gauge? what are you running?
Old Nov 14, 2001 | 02:48 PM
RestoTII's Avatar
I've got a boost gauge, but the dumbfuck that put it on the car before I bought it put it in the wrong place. I reads anywhere from 0 up to 10-12 psi. I'm assuming it's half assed accurate at full boost since I was estimating that I should be pushing around 10 psi. I'm going to hook the boost gauge up right over thanksgiving break since I don't have enough tools up here.
which route should I take with adding more fuel? Is the fuel pump/rewire first up, or should I bump up to 680cc secondaries? Thanks
Old Nov 16, 2001 | 01:00 AM
Scott 89t2's Avatar
SOLD THE RX-7!
I bet you are running 10-12psi, could be even higher if you had an intake. you are running to much for the stock system. where is the gauge now?? and where did you plan to put it?
Old Nov 16, 2001 | 01:32 AM
Gab88na's Avatar
totally agree
go with the flow
more fuel is the way to go =)
rgordon1979
40
Mar 15, 2022 12:04 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
sherff
Sep 12, 2015 12:22 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
