Downpipe coating
Old Nov 13, 2001 | 11:33 PM
coop's Avatar
Downpipe coating
Is it worth having a downpipe coated with something to help keep the heat away from the engine?
I see someone has Thermotec wrap...what is that/where doe you get it/ does it help?
Also is it worth having the pipe sent off to have it ceramic coated?
I figured I would look into this stuff *before* I installed it.
Thanks
Dave
Old Nov 14, 2001 | 12:29 AM
Flybye's Avatar
It's never fast enough...
I use www.jet-hot.com. They have coatings up to 2000 degrees and are VERY durable. I can tell ya my buddy that had a 500hp mustang, well the interior was HOT as hell. He had the entire exhaust system coated, and there was a massive difference in temperatures in the car.
Old Nov 14, 2001 | 06:38 AM
RichJ's Avatar
I'm still looking for my FD, but when I find one I'm going to get the downpipe Jet-Hot coated if it hasn't already been coated. Header wrap works too, but it's a pain to put on and get to stay on, and if it gets oil on it -- watch out -- it will burn!!!
Rich
Old Nov 14, 2001 | 06:56 AM
coop's Avatar
Jet-hot prices?
Can I ask how much it costed you to have your DP coated?
I am curious.
-Dave
Old Nov 14, 2001 | 07:02 AM
RichJ's Avatar
Hey, if you do go to Jet-Hot, check this out. It was emailed to me by a friend:
IMPORTANT MESSAGE from JET-HOT
INTAKES$50off MUFFLERS$50off OIL PANS$50off
CALIPERS$50off VALVECOVERS$50off SUSPENSION
$50off MANIFOLDS$50off TUBING$50off HEADERS
$50off CARS$50off TRUCKS$50off SNOWMOBILES
$50off ATV's$50off PPC's$50off...get the idea???
ANY ORDER over $200, $50 off!!!
(see below for order values from $25 - $199)
JET-HOT COATINGS, your favorite High-Temp coating company, will
take $50 off your next order! We coat everything listed above & more!
Simply print a copy of this form and enclose it with your parts. We'll
take $50 off any order valued at $200 or more (see below)!!!
PRICE & SHIPPING INFORMATION:
(800) 432-3379 Select Option #2
8AM - 9PM EST, Mon/Fri
9:30AM - 5PM Sat
SALES@JET-HOT.COM
Please: pass this to a friend if you are unable to use it now!
$200 minimum order value for $50 discount: orders from $25 - $199,
take 10% off.
May not be combined with other discounts, reductions or special pricing
This coupon (or a copy) must accompany any order to qualify
One coupon per order Discount applies only to coating services:
Shipping, Jet-Hot Direct Headers or other special services are
excluded.
OFFER EXPIRES 12/31/01
Sincerely
Todd & Chris
Jet-Hot Coatings
Old Nov 14, 2001 | 07:18 AM
Dark Side's Avatar
Jet Hot
"ANY ORDER over $200, $50 off!!!
(see below for order values from $25 - $199)"
If you are only going to get your DP coated this will not be applicable as the Jet-Hot 2000 coating will cost you about $60 ($20/ft)
I think this coating is FAR superior to a thermal wrap.
Old Nov 14, 2001 | 07:23 AM
RichJ's Avatar
Hmmm...guess you are right about not being able to use the special. Well, you could always send them the intake manifold to be coated as well. It would look really nice with Jet Hot coating and might even keep the underhood heat from contaminating the cooled intake charge
Rich
Old Nov 14, 2001 | 09:25 AM
Flybye's Avatar
Here are pics of my upper intake and Y-pipe coated. Keep in mind you can NOT use this same coating for OUR exhaust. The coating we need for the exhaust doesn't have a shiny texture to it and is flat.
My Y-pipe was about $50 and my intake was about $150. I only have a gutted precat, but it's safe to assume a DP to coat will be around $50-$80.
