bigger radiator
Old Nov 13, 2001 | 10:29 PM
njm's Avatar
njm
bigger radiator
can anybody advise me about the best aftermarket radiator ? i want a direct bolt in replacement with the best cooling capacity. thanks
Old Nov 13, 2001 | 11:42 PM
Sidestick's Avatar
Fluidyne seems to be the big thing now. Koyos may be a little cheaper, but may have slight fitment issues.
Old Nov 14, 2001 | 09:29 PM
G 's 3rd gen's Avatar
Lightbulb
I just put in a Koyo and it was a bit of a pain in the *** if you are going back with stock intercooler and battery tray. I had to shave the intercooler mount and raise the battery tray with spacers to keep the fans from rubbing. Also had to drill out a hole the size of the bottom of the ac dye bottle in around fan shroud in order to fit it. It was definately worth it...It cools like a son of a bitch!!!Good luck,G...
Old Nov 15, 2001 | 03:03 AM
MeLoco's Avatar
Go with the Koyo it's worth it.
Old Nov 15, 2001 | 02:22 PM
tristarx's Avatar
Koyo & Fluidyne
Here are some pics:
- The Koyo
The Koyo are 55mm thick! Which is why many have to extend their brackets and modification for it to fit.
- The Fluidyne
The Fluidyne are alittle more expensive than Koyo by about $25.00 more.
Tx.
Old Nov 15, 2001 | 02:30 PM
Mahjik's Avatar
Mr. Links
Absolute_Radiator
There are some ok prices at that place.
Old Nov 15, 2001 | 02:56 PM
solo1seven's Avatar
Hey,
I just received my koyo radiator from Chris at absolute radiator. Excellent service, great pricing. The Rad looks really good, supposed to provide better cooling than the fluidyne (it's thicker) and be a drop in, haven't installed it yet to confirm that though.
Andrew Wojteczko
93 RX7 R1
Old Nov 15, 2001 | 03:02 PM
az_lynx's Avatar
Originally posted by solo1seven
Hey,
Andrew Wojteczko
93 RX7 R1
Absolutly!.. But I got the fluidyne, got it a bit ago from Absolute also... great service and fast shipping! Installed it w/out a single problem. O wait... I take that back.. it didn't come w/ a drain plug.... so one suggestion... make sure you get the drain plug BEFORE you put it in. That way you can be sure to get the right size and not have to buy a few different sizes
MidnightOwl
Sep 25, 2015 10:24 PM
