Just installed single setup, what to expect on startup
Old Jun 29, 2004 | 03:06 AM
Indo Audio's Avatar
Just finishing up a single setup.
Apexi RX6b turbo kit
1300CC secondaries
walbro fuel
sx fpr
PFS SMIC
Apexi GT Spec
XS ignition
GReddy pulleys
power fc
midpipe
everything eliminated/block off plates
What should I expect on startup? What should I do on the baseline fuel maps just to get it to XS engineering for dyno? Can i drive with no boost, basically ride it real gently to the tuner?
Thanks for the input,
Ravi
Old Jun 30, 2004 | 09:11 PM
Indo Audio's Avatar
Old Jun 30, 2004 | 09:57 PM
twokrx7's Avatar
Need more sleep
IF you bought your stuff from them and they are doing the tuning then let them load a base map to get you to the dyno. I would not let them tune my car after seeing their ignition maps but YMMV.
Make sure you have proper fuel pressure and keep it out of boost, you should be fine to drive it to the dyno. Might change the secondary injector size to 1300 so you don't flood it when the secondaries come on, just in case you have to dip into the throttle a bit more than expected that is.
Old Jul 1, 2004 | 04:46 PM
Indo Audio's Avatar
Thanks for the help, will try it out
sherff
Feb 24, 2019 12:09 PM
Skeese
65
Mar 28, 2017 03:30 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
