Sponsored by: CARiD
series 4 T2 problem
Old Jun 27, 2004 | 02:53 PM
madscientist's Avatar
series 4 T2 problem
here's a run-down of my engine:
140,000km on odometer (approx 85k miles)
intake cone filter
downpipe
high-flow cat
cat-back exhaust
manual boost controller
DIY fuel cut defenser
ok, here's my situtation...
my exhaust is SPEWING white smoke like there's no tomorrow.
i'm assuming it's the coolant seals that have finally failed on me? am i right?
oh, as an added note...this started happening out of nowhere. on friday, i drove the car all day, and it seemed fine. ran fine.
i parked it, and later restarted it and that's when this started happeneing.
so what is wrong with the engine?
Old Jun 27, 2004 | 05:40 PM
SAiamNE's Avatar
Do you coolent seal test.
If you don't know what that is, feel free to use the search button..
Old Jun 27, 2004 | 09:51 PM
diabolical1's Avatar
what does the smoke smell like? are your plugs wet? do you get extra pressue in the cooling system? are overheating?
how is your turbo? what is your oil consumptions like?
sorry for the bombardment of questions. many people swear solely by color of the smoke, but i have proven that oil can burn white (as opposed to blue) at times and i'm not convinced that it may not be an oil problem.
need some more info ...
Old Jun 28, 2004 | 03:22 AM
i have yet to do the coolant pressure test.
but...as for the oil consumption...it is perfectly normal. the turbo seemed fine as it was boosting normally earlier on friday.
as for overheating, yes, it does seem to climb very quickly...i can notice the needle climb up the gauge even after just a few short bursts of boost during freeway driving. when i say short bursts, i mean NOT wide open throttle...just adding enough throttle to make it boost and pick up speed to pass, etc.
my plugs are heavily fouled...they've been in the car for less than 1500km..
lemme take a stab at it....
rebuild time right?
Old Jun 30, 2004 | 09:14 PM
RETed's Avatar
Sounds like oil to me.
Check the turbo compressor and intercooler pipes - is there a lot of OIL inside?  If so, the turbo needs to be rebuilt.
Do a high idle test - rev to 4kRPM and hold for 20 seconds.
Do you have a lot of smoke out the exhaust?
If so, oil control rings are shot - requires rebuild.
Make sure your "PCV" is working properly or at least not pressurized.
You might want to remove the oil filler cap to see if this changes anything.
-Ted
ZacMan
Sep 19, 2015 09:20 PM
ncds_fc
19
Sep 15, 2015 12:03 AM
sinistersam
Sep 13, 2015 07:17 PM
