fule leak!!!!!!!!!!!!!!!!
Old Jun 25, 2004 | 10:36 PM
RandyTibbles's Avatar
Okay,the thing that is leaking is called a pulsation damper,it's in the front under the 4 intake pipes,to the left. anyway, this thing has a phillips head screw in it that has came out and wont go back in! and yes gas is comming out!!!! so where do i get a new one?
Old Jun 25, 2004 | 11:45 PM
gsl-se addict's Avatar
Super Moderator
You can get a replacement PD at Mazdatrix or the dealer. I believe they are about $160. Also, search this site for the banjo bolt pulsation dampner mod. Most will be in the second gen forum. In this mod, you replace the PD with a banjo bolt. This way you don't have to worry about leaking in the future. Most say that it will not hurt performance, etc. However, the fuel pressure fluctuations may shorten the life of the fuel pump or injectors.
Just make sure that you fix it right away. Many RX-7's have had extensive fire damage due to a leaking PD.
Kent
Old Jun 26, 2004 | 01:59 AM
mazdaverx713b's Avatar
Have RX-7, will restore
also, with it leaking, please do not drive it. your engine is VERY prone to becomeing ablaze!
ls1swap
Jun 3, 2024 03:25 PM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
James Knox
Oct 5, 2015 07:56 AM
