Direct Fire Kits are HERE
Old Jun 23, 2004 | 10:56 PM
V8kilr's Avatar
Ok sorry for the long long long wait.
The "Lite" Kit is here with pricing, the other kits are still unfinished because I changed the design slightly and need to finish testing them.
SO here goes.
Flame Works Lite
Complete bolt in kit less mounting equipment (I had some aluminum brackets fabbed up but after the price of aluminum and the price to have them made it just wasnt worth it. So I figured you guys can get creative on mounting).
ALuminum case with a heatsink design to help disapate heat (3.54"x2.0"x4")
Kit comes with unit with 2 independant ignition modules ready to drive 2 coils (coils are included)
All wiring and connectors are included (but not shown).
Price $175.00 Coils included
Flame Works
The Flame Works kit is slightly larger then the kit above but same style box (4.13"x2.36"x4").
It uses neutrix connectors, features increased current flow.
The ignitors deliver up to 50% more energy then the unit above.
Features a dwell control circuit that ensures long, consistent coil charging and the current control circuit protects against coil overheating and resists false triggering from the RFI of high output coils.
Price $200.00 Coils optional
Flame Works Pro
The Flame Works Pro kit is even larger then the Flame works kit measuring in at (4.13"x2.46"x8").
The Pro kit features everything in the Flame Works kit with the exception of even better ignitors.
The Pro ignitors will deliver a consistant fault proof spark to 9,000 rpm.
They feature 25% higher coil drive currents than the Flame Works model. This saturates the coil faster, which gives you more spark energy at high rpm.
Price $250.00 Coils optional
Old Jun 23, 2004 | 11:34 PM
hornbm's Avatar
FD > FB > FC
So what if were a lazy *** and would pay u for the brackets anywa?
Old Jun 24, 2004 | 09:58 AM
allforjesus06's Avatar
i love assembly lube
nice product
Old Jun 24, 2004 | 10:18 AM
OtakuRX's Avatar
The Rotorheaded Geek
nice, soon as I can save up a bit you will have a buyer here.
Old Jun 24, 2004 | 11:02 AM
V8kilr's Avatar
Mantis may be taking care of the brackets.
Alex-7's Avatar
Very Nice!!!
I'll be in the market soon.
Did you put this on Sterlings backyard co-op thingy yet?
Also, if you where to produce mounting brackets (as an option) I would buy them, I'm not very creative I guess.
Old Jun 24, 2004 | 11:13 AM
thafox's Avatar
nother rican witha rotary
what kind of coil's are those?
Old Jun 24, 2004 | 11:39 AM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Nice job! Worth the wait!
Get it up my site, too! There's not much action there cause there's only a few things featured.
I'm in for a Flame Works Pro kit when I see a little more info.
Maybe we can work out a deal on your Sterling Carb order.
Old Jun 24, 2004 | 11:54 AM
Tom's Avatar
Tom
Whack 'em and stack 'em
From: Clarksburg/Bridgeport WV- North Central Appalachia
Does the 'box' have to be mounted in the engine bay area, or can it be re-routed inside the cabin (save mounting space/brackets). Any problems posed with this idea?
Old Jun 24, 2004 | 11:59 AM
FB II's Avatar
i'm game
Old Jun 24, 2004 | 12:46 PM
twigg's Avatar
Its an addiction.
what are the benefits of direct fire?
Old Jun 24, 2004 | 01:08 PM
RotaryRyan's Avatar
DSM
If this is the thread im thinking of .Read
Old Jun 24, 2004 | 01:23 PM
bouis's Avatar
The biggest difference I noticed with an MSD direct fire was vastly improved cold starting and a very stubborn refusal to stall when cold, or any situation where it doesn't fall too much lower than than the lowest mark on the tach (500 rpm). It feels like it could probably idle at 400 rpm (though not smoothly).
What benefits would this kit have over an MSD? The price is about the same and the MSD is proven and comes with a warranty. Also, the rev limiter on the 6AL DOES work.
Old Jun 24, 2004 | 01:31 PM
Alex-7's Avatar
Yeah but I would rather supprot forum member personally.
V8klr, does your kit have a rev limiter or can one be incorperated
Old Jun 24, 2004 | 02:42 PM
GavinJuice's Avatar
Leave A Message
So the Flameworks and the Flameworks Pro packages come standard with or without the coils at the estimated price? You have coils optional for those two, and coils included with the Lite version. I just want to be sure on this. ~Gavin
Old Jun 24, 2004 | 02:47 PM
riofrio's Avatar
This IS a tasty burger!
Awesome... I'll definitely get one before the end of the year.
Old Jun 24, 2004 | 04:18 PM
V8kilr's Avatar
Sounds good, the other 2 kits will be posted the second week of next month, that is also when the 3 kits will be avail and the new site will be up with credit card and paypal ordering online.
Old Jun 24, 2004 | 04:20 PM
V8kilr's Avatar
Mount it wherever you want, but keep in mind I only include a certain amount of wire, anything after that you are responsible for, ontop of that you will loose current and weaken the signal strength both from the magnetic pickups and to the coils if the wires are too long.
I would say underneath the dash on the driver side might be the furthest.
Also remember if you choose to mount the system there you might get RFI interferrence with your car radio.
Old Jun 24, 2004 | 04:24 PM
V8kilr's Avatar
all of my systems iincorporate 2 independant ignition systems in one unit.
I could make it like a 6a with 1 system capable of running 2 coils and the Flameworks kit would literally cost $80 less, so your basically getting 2 6a's for $200
Old Jun 24, 2004 | 04:26 PM
V8kilr's Avatar
working on a rev limiter and a very touchy pickup for the unit.
The new pickup circuit can detect movement change in the distributor at just 100 rpm
Old Jun 24, 2004 | 04:32 PM
V8kilr's Avatar
The higher end systems come without coils
This is because I recomend these coils instead of the ones that come with the lite kit.
$35 coil
$50 coil
$36 msd coil
$110 msd coil
$130 msd coil
Just pick which ever ones fit your budget, the higher priced coils are the better, excpet the $36 msd is tied with the $35 coil.
Remeber you will need 2
Old Jun 24, 2004 | 09:41 PM
GavinJuice's Avatar
Leave A Message
Wow, no in between from $36 to $110 in the MSD. Any thoughts or experience on the jacobs coils? Here's what i'm talking about. http://store.summitracing.com/partde...t=JAC%2D380876
Old Jun 24, 2004 | 10:27 PM
lovintha7's Avatar
Suicidal Death Missile
what's the advantage of direct fire?
Old Jun 24, 2004 | 10:41 PM
V8kilr's Avatar
SUre that would work
I just posted some recomendations above, theres tons of coils that will work though
V8kilr's Avatar
check the 1st gen archive for all your DFI questions
