anyone else have this problem
Old Jun 22, 2004 | 08:24 AM
tjgosurf's Avatar
Squeak, Suicide Girls
Ok, I have had my fb for almost a month now, and i've noticed something thats kinda disturbing. It takes forever for the radiator to cool off. the engine doesnt run hot, it just keeps pressure for a long time. anyone else got this problem?
Old Jun 22, 2004 | 08:52 AM
Metallic_rock's Avatar
Ride 'n Style
replace your radiator cap...
also, if you don't have the stock thermostat with the small hole in it, that could be causing part of the problem (unlikely, though)
Old Jun 22, 2004 | 09:13 AM
RX7Rox's Avatar
Southwind Seven
If the engine is not running hot or overheating, I wouldn't be too concerned. With it still holding pressure, it's probably a good sign...meaning no internal/external leaks. The car goes thru a "hot soak" stage after shutting off the engine. The coolant flow stops and the engine temp will rise before it starts cooling off. Other factors would effect cooling is outside temperture. If it's 100 deg outside and you park in a garage, it will take longer. I know with my car after driving it will actually heat up my 2 car garage.
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
