Power FC getting a map/general questions
Old Jun 21, 2004 | 09:54 PM
Slam Pig
well I am at the last step I hope...
First thing first...my mods
Non Seq (with ported waste gate)
Street ported motor (seems like a rather large port too)
Apexi Intakes
Apexi FMIC
Removed Double Throttle
Large Fuel Pump (yes I did my fuel filter and also wired my relay to run full pressure all the time)
3 inch DP
3 Inch MP
Greddy PE Cat Back
AVC-R for boost
and the Power FC for fuel...
Now im getting this crap tuned ASAP..but I cant be finding all my mistakes while on a tuners time with my car sitting on a dyno...with the base map can I run boost, if so how much..Also does anyone have a map for these mods (I tried dling one which seemed perfect for me in the map section but it didnt work)..
thanks guys
Old Jun 21, 2004 | 09:57 PM
Slam Pig
as a side note...my injectors are stock
Old Jun 22, 2004 | 10:01 PM
alberto_mg's Avatar
a good tuner can get this done in 1 hour or so on the dyno. maybe up to 2 hours.
Old Jun 23, 2004 | 12:46 PM
Slam Pig
yeah i know...but the problem is I need to test my car before driving 200 miles to a tuner....it has not started since november...
Old Jun 26, 2004 | 12:44 AM
Newbie
You shouldn't have any problems if you go easy on it. Get to a tuner with a wideband. You should be ok as long as everything remains stock. Fuel pressure, etc.....
Just don't go above 8-9PSI until you get to a tuner. If your port is big then it will kick in and lean out big time around 4500-5500 RPM. Stay away from WOT accelerations too until you get it tuned. It shouldn't take long to correct the values unless you are tuning from 9psi -17psi, and even then someone experienced will already have a good base knowlege of what works and doesn't. Just my two cents from a ghost.
Old Jun 26, 2004 | 12:46 AM
Newbie
Oh yeah! go into settings on the function menu and switch the seq. turbo op. off. That will get rid of the stumble.
Old Jun 27, 2004 | 01:15 AM
Slam Pig
cool thanks bro...im firing my car up tomorow...
once again thanks
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
