Cracked Trans Housing
Old Jun 21, 2004 | 05:08 PM
While attempting to remove a bolt (that holds on the slave cylinder) that had broken off I cracked the housing. Can I repair it (How?) or do I need a new tranny?
Thanx
Michael
Old Jun 21, 2004 | 05:10 PM
Kenteth's Avatar
Like Ghandi with a gun
cracked the bell housing? Its unobtainium but it can be welded at a shop, (don't even consider doing this yourself... aluminum will kick your *** if you try to weld it and aren't a professional). You could consider JB weld, butthe bell housing transfers a good portion of hte tranny's wheight to the engine and engine mounts, not sure how well JB weld would hold up in that situation...
R7rexy
19
Sep 2, 2015 10:24 AM
