Power FC Help Datalogit not working!!!!!
Old Jun 18, 2004 | 11:24 PM
NESpeed's Avatar
Ok after a long wait to get the stupid thing, i finnaly got time to put it in. Went for a drive logged alittle then gased up. Now its all screwed up, error 76.....can not interface. And the commander stays on the boot screen and stays there with the APEXi logo!! I am lost?!?!!?
Old Jun 19, 2004 | 08:08 AM
skotx's Avatar
Registered Abuser
I think with older versions of the Datalogit software, there was a specifc order in which you had to do things, like start the car, then fire up the software. If you shut off the car when you got gas and left everything plugged in, then maybe it got confused. I think this has been addressed in newer versions of the software, available on the yahoo group.
Just start from scratch: take the Datalogit out of the equation and make sure the Commander is working properly, then try the Datalogit again.
Old Jun 19, 2004 | 08:10 AM
shawnk's Avatar
Perpetual Rebuilder
Check your plugs, and if everything feels good then take the datalogit out and see if just the commander works. If it does work then you know that the commander is good and the port on the PowerFC is good and the problem is either with the connections or the datalogit. If the commander alone does not work then something is wrong with the commander or PowerFc port is bad.
Oh and I am not sure if it matters or not but I never plug or unplug that stuff when powered so if something happens and you start messing with the cables turn the car off.
Old Jun 19, 2004 | 12:14 PM
rdavidsrx7's Avatar
block-spike
Re: Help Datalogit not working!!!!!
A friend of mine has this same thing goimg on, I may have jinxed him the other day. Any other insight on this...NE did yours get fixed?
Old Jun 19, 2004 | 04:29 PM
NESpeed's Avatar
Ya...I had tryed that lastnight. Everything is fine with out the datalogit. Im gonna try a few things tonight. Ill let ya know what happends.
Old Jun 20, 2004 | 07:31 PM
Wargasm's Avatar
Weird Cat Man
I had a 100% working setup... then my company gave me a new laptop... and I couldn't make the thing work. I eventually gave up on the serial port, bought a USB to Serial port converter and it works fine now. Maybe you should pick up a converter (around 20 bucks?) and try it out.
Brian
Old Jun 21, 2004 | 01:25 PM
NESpeed's Avatar
i have the usb......im calling rx7.com as i type. thanks for the help though
ricardo.benin
Power FC Forum
Aug 20, 2015 08:32 PM
