buzzing speakers
Old Jun 18, 2004 | 12:13 AM
loren's Avatar
buzzing speakers
my drivers side speaker makes this horrible buzzing sound. my rear subs make a gargling sound like theyre under water. i searched the forums and didnt really find anything helpful to my situation. anyone have any suggestions? is there a way to fix the problem?
thanks
Old Jun 18, 2004 | 12:14 AM
loren's Avatar
btw i have them both disconected...is this bad?
Old Jun 18, 2004 | 12:20 AM
WaLieN's Avatar
Call me gramps!
Do you have the Bose system in your car? If so, it's possible that your amps are blown.
Old Jun 18, 2004 | 09:33 AM
loren's Avatar
yea its bose. do i need to replace with bose or just go all new?
Old Jun 18, 2004 | 09:51 AM
Mahjik's Avatar
Mr. Links
Arrow
http://carstereohelp.com/mazda.htm
Old Jun 18, 2004 | 11:09 AM
mgoddard1's Avatar
I luv my carbon footprint
<threadhijack>
My bose system has a similar problem and I was looking for a good place to have it repaired. Thanks for the link Mahjik.
</threadhijack>
Old Jun 18, 2004 | 08:50 PM
$100T2's Avatar
On the prowl for an FB
Yank it and go aftermarket.
Old Jun 18, 2004 | 11:31 PM
Iggy76's Avatar
This sounds like a ground loop problem... The Bose transmission line system is fantastic... keep it. Replace the internal speakers maybe... upgrade the wiring.
Old Jun 19, 2004 | 09:52 AM
Molotovman's Avatar
Ban Peak
I'd say ground too. Its like when you plug a guitar cable into an amp, and then put your tongue to the end.
Old Jun 20, 2004 | 03:23 AM
WaLieN's Avatar
Call me gramps!
I agree with Mahjik. I had 2 amps repaired from these guys -- and afterwards, they come with a lifetime warranty.
An alternative is to buy a used system off the forums -- I know for a fact that there are a few people selling stock Bose amps/speakers.
If you ever heard the stock Bose system with a better headunit, you will realize that it is a very nice setup. It fills all the ranges, while also maintaining quality under high volume (not volumes that will make your ears bleed, but high enough to muffle the motor). If you don't plan on bumping Rap at excessive volumes that will force others to listen to your music, the stock Bose system is fine.
RyanFox
Sep 18, 2015 09:09 PM
The1Sun
Sep 18, 2015 07:13 PM
