help brakes.....
Old Jun 16, 2004 | 05:44 PM
87base RX-7's Avatar
help brakes.....
okay 87 base model not converted too 5 lug yet so i still have the single pot brakes they seem be set a little too tight on the wheel as in it takes a good bit of force too get the rotors too turn with the wheels off also there sqeekin when im jus drivin then go away when i depress the brake so yea is this how our brakes are suposed too be or not and if not where and how do i adjust this ? thanks any help would be apreciated
Old Jun 16, 2004 | 05:49 PM
SAiamNE's Avatar
Put the wheels on and see how hard they are to turn. The pads will still "sit" on the rotor as they will not completly back off from it. They shouldn't be that hard to turn. If they are you have not pushed you pistons back in far enough when installing ur new pads. Use a C Clap to push them back in. They should go back in with little effort.
As for the sqeeking.. Did you apply any " brake quite" when installing the new pads, or use shims?
If not go out and buy a bottle of "Brake Quite". It comes in a red bottle and is almost a silicone that you apple to the back of your shoes where the piston touches. It doesn't let the metal contact each other and therefore you don't get that sqeek.
Old Jun 16, 2004 | 06:07 PM
alright thks man and my pads are old so te sqeeking might jus be the ware indicator (i took the wheels off too check them cause i brake alot on the back roads around here and dont need them too give out on me lol) and i didnt notice them bein this hard too spin till now (i rotated my tires bout a month ago and dont remember them bein this tight)
JimBot
Jul 23, 2004 08:57 PM
darkwaveboi
Jun 23, 2003 08:42 AM
79+80_rx-7
Apr 25, 2002 02:20 PM
