i've got $3730 and i need to know what i should buy for HP
Old Jun 16, 2004 | 10:06 AM
RX-7/FC3ScraZ!'s Avatar
Question i've got $3730 and i need to know what i should buy for HP
what can i buy that will raise HP the most with about $3830 or about $5000 canadian.
Old Jun 16, 2004 | 10:23 AM
DylanShupe's Avatar
Save up some more and do a 20b swap.
What year is your car and maybe I can give you some ideas on upgrades.
Old Jun 16, 2004 | 10:25 AM
KNONFS's Avatar
B O R I C U A
Start with a stand alone, from there you can do anything you wish!
Old Jun 16, 2004 | 10:34 AM
Mr. Gadget's Avatar
Older than Dirt
FULL COMPLETE TUNE-UP (if not rebuilding do this first)
Replace ALL fluids
then,
CAI, have injectors serviced, true duals, lightened flywheel with better clutch Thats about 1500, spend the balance on a full rebuild with a professional port job, port match the intake. TB Mod and the list goes on and on and on and on
Old Jun 16, 2004 | 10:36 AM
OverDriven's Avatar
Anyone gonna ask him if its a Turbo or N/A?
-Joe
Old Jun 16, 2004 | 10:46 AM
DylanShupe's Avatar
I like the 20b swap idea myself.
Old Jun 16, 2004 | 10:55 AM
Jaared's Avatar
Ahhhhhhhh hhh....
20b is gonna cost $15k to $20k.. so ummm,..,...
turbo or n/a?
if you got that much and you have a n/a then sell the n/a and get a turbo.
Old Jun 16, 2004 | 11:20 AM
fc3seeker's Avatar
T2 Noob.
You make it sound like its a simple task.
Old Jun 16, 2004 | 11:24 AM
2ndGen.rocket's Avatar
Ho's and Cadillac Doors
Re: i've got $3730 and i need to know what i should buy for HP
A Camaro.
Old Jun 16, 2004 | 02:18 PM
Mizeru's Avatar
V8 Swap...I'm serious
Old Jun 16, 2004 | 02:22 PM
SonicRaT's Avatar
Super Raterhater
Only 340rwhp on your v8 swap? Damn.... you really need to hop that thing up some more!
Old Jun 16, 2004 | 02:34 PM
Mizeru's Avatar
Untuned; originally carb was too big; bad distributor I will have new dyno numbers in the next month. Notice the torque dropoff in the topend. That should be gone with the 3 fixes to the problems above, thus giving me up to another 100RWHP.
Old Jun 16, 2004 | 02:43 PM
SonicRaT's Avatar
Super Raterhater
Damn, I was gonna say something ain't right. With that power you could've just turbo'd it for less and got that! Still waiting for my coworker to pop his engine so we can drop in my 355.
Old Jun 16, 2004 | 06:47 PM
my dad is going to buy me an 88 turbo FC, so i don't have it yet because i'm only 15, but my birth day is in less then a month and i need to know what is the best thing to buy when i get it. i want to get the most HP out of my money.
Old Jun 16, 2004 | 06:51 PM
Icemark's Avatar
V8 conversion and simular posts are limited to the Other Engine sections of the board, and not recommended to be posted in the 2nd gen technical section (here)
Old Jun 16, 2004 | 06:52 PM
Icemark's Avatar
Save your money for insurance, and for when the car breaks down (which it will do for a 16 year old driver).
Old Jun 16, 2004 | 07:18 PM
DEZERTE's Avatar
777** The Anti-rice
I wouldnt do this, Id buy a t2 if you have that k inda money, if you already have a T2, then cool.
Old Jun 16, 2004 | 07:28 PM
Mr. Gadget's Avatar
Older than Dirt
16 = NA, learn to drive (of course I know all about the professional go cart drivers learking out there)
18 = turbo - can afford the habit
or, just be one of my kids and daddy will build it!
Old Jun 16, 2004 | 08:02 PM
88IntegraLS's Avatar
Displacement > Boost
If you have a NA, sell it and get a TII and do exhaust, fcd, fuel pump, safc and some dyno tuning. Or buy a V8 RX7, or do the swap urself for more expense.
If you like NAs then block porting, exhaust, and Safc + dyno tuning in that order would be my humble recommendation. Don't forget to get some light stock 15x6 wheels (91 coupe five stars, bbs vert wheels, or Millenia or 929 wheels are all around 12 lbs each).
And have fun!
Old Jun 16, 2004 | 08:38 PM
vaughnc's Avatar
knowledge junkie
For $3830 you could bolt on a complete 7" supercharger kit and have money left over This one requires no ECU mods or injector changes as it has it's own built in injectors. I think you might need a larger fuel pump though.
http://www.atkinsrotary.com/store/cu...cat=285&page=1
Old Jun 16, 2004 | 08:50 PM
SonicRaT's Avatar
Super Raterhater
Funny that we seem to support anything else you can cram into a 2nd gen (20b, RE, etc).
Old Jun 16, 2004 | 09:13 PM
Hex7E's Avatar
I am segfault
For not I would say learn to drive, you don’t want to have high hp when you start driveling, you will waist your car. i would learn to drive, and while you are at it learn about upgrading your turbo system. Also keep in mind if you want to add hp it will add strain to your motor, which will likely be a high mileage engine. Which means I would get now with a blown engine, put some of that money into giving it a fresh rebuild with RA apex seals, them maybe use some of the left over money to get your self a bigger turbo with an external waist gate, upgrade your injectors and fuel pump, get a safc, and such.
Old Jun 16, 2004 | 10:18 PM
rosey's Avatar
If you want the most "hp" from a TII, just buy a T-88, or some other rediculously huge turbo and bolt it on. Then take the pipe on the manifold that is for connecting a wastegate, and weld it shut.
Seriously, learn how to drive before you worrie about how fast your car is....if you just want a lot of "hp" buy a mustang, camaro, T/a, V8 whatever. If you do buy an rx-7 and want to mod it AFTER you learn the basics of driving, then do research on the set-up you want, we can't tell you what you want to do with your car.
Old Jun 16, 2004 | 10:32 PM
Icemark's Avatar
No, those generally will get moved as well
Old Jun 16, 2004 | 10:51 PM
NArotaryfan's Avatar
just my 2 cents but
id save it for things that break as you drive it and learn to drive it. and as your skills develop and if the car doesnt break at all by then i would put the money into handling
like tires, springs, shocks, strut brace, brakes things like that that seem to get overlooked when thinking about fast cars
