T78 Turbo blew - help with troubleshooting
Old Jun 15, 2004 | 02:01 PM
Rx7oneluv's Avatar
I just installed my Engine and hooked up the T78 and drove it for the first time today. I reached about 6lbs-8lbs of boost and I heard a large pop from my engine bay. Pulled it over to see that the turbo blew the Elbow off of it. Now the turbo is smoking very bad and oil is leaking from the front turbine. The car still idles perfect and drives ok.
I'm curious to what might have caused this. Hopefully I don't have to overhaul the turbo. The turbo still spins freely. I'm curious to if this is my Wastegate or BOV that cause the problem.
Any help would be greatly appreciated.
Thanks
Old Jun 15, 2004 | 06:42 PM
SPOautos's Avatar
Hey, where did my $$$ go?
doubt it was wg or bov issue when only running 6-8psi.
If you grab the compressor wheel by the front nut can you move it side to side enough to touch the housing? Also check to see if you can you move it in and out???
It sounds like the thrust bearing went out causing the compressor wheel to smack the compressor housing. If thats the case then yes...its rebuilt time. One of the causes of this could be it not being balanced correctly or maybe someone just didnt seat the compressor housing flush.
STEPHEN
Old Jun 15, 2004 | 06:48 PM
XSTransAm's Avatar
Ee / Cpe
are you boosting a new engine without breaking it in?
Old Jun 15, 2004 | 07:18 PM
Turblown's Avatar
Turn up the boost
That sucks Ken. Goodluck.
Old Jun 15, 2004 | 07:36 PM
setzep's Avatar
If I had to guess I'd say the hose wasn't on very well and you have too much oil pressure to the turbo or not a big enough return line from the turbo.
Old Jun 15, 2004 | 08:33 PM
Rx7oneluv's Avatar
The engine already had 5k miles on it, and it runs great. So yes I was boosting to the engine, but its already been broken in. The bearing in the turbo must have gotten metal flakes in it, because I took it apart and the housing is scored slightly.
Curious to if anyone knows any companies that can rebuild T78s.
Old Jun 15, 2004 | 08:37 PM
Rx7oneluv's Avatar
another question. Anyone ever setup a secondary oil filter just for the turbo? I was thinking of spliting the feed line and adding a secondary small oil filter. Just a thought. Is this a good idea?
Old Jun 16, 2004 | 04:10 PM
$150FC's Avatar
Currently Winning
I think BNR can rebuild a T78. (205) 640-1193
Old Jun 17, 2004 | 04:55 PM
rx7tt95's Avatar
Photo Diety
Majestic Turbo in Waco, TX can rebuild them and even upgrade them with in their words, better compressor wheels. Jason uses one of these modified T78's as did I for a while before switching to a GT4082.
Michel
Old Jun 18, 2004 | 11:46 AM
Rx7oneluv's Avatar
I went to majestic turbo and they are going to have it to me on saturday. Fast service, best value....I highly recommend them.
Old Jun 18, 2004 | 02:04 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
another enthusiastic vote for Majestic. talk to Kevin Draper
howard coleman
cristoDathird
28
May 30, 2019 08:47 PM
Skeese
65
Mar 28, 2017 03:30 PM
Snoopy FD
Dec 8, 2015 01:45 PM
Snoopy FD
Aug 19, 2015 03:40 AM
