cusco rear strut bar
Old Jun 15, 2004 | 08:39 AM
HI!
does any one have the directions on how to in stall them? if someone does could you possibly e-mail them to me at scp_007@hotmail.com. thank you
Old Jun 15, 2004 | 08:44 AM
jon88se's Avatar
Eat, sleep, work, mod.
Ummm, it should be pretty self explanatory. Take off your speakers in the rear strut towers and expose the top strut mounts. Install the plates for the rear bar on either side and cut 2 holes in the rear shock towers for the bar to pass through. Mount the bar and you're done.
Old Jun 15, 2004 | 09:48 AM
Relisys190's Avatar
REINCARNATED
Jon is correct... You'll need to make provisions in the factory strut towers for the lateral strut bar to pass through. Otherwise the unit will not be able to be bolted to the fasteners that mount to your strut tops.
Good luck.
Regards,
-Markus R
Old Jun 15, 2004 | 12:21 PM
jon88se's Avatar
Seperating the carpet from the metal around the strut towers makes things much easier/neater. The metal will drill out MUCH easier this way (it's very thin). Then, just cut a slit in the carpet for the bar to pass through on either side, it will look great.
Old Jun 15, 2004 | 01:20 PM
carx7's Avatar
I actually used a new hole saw on my drill that was *just* slightly oversized for my rear bar (mine's circular).
The holes saw cut the carpet and metal in one shot and leaves and extremely professionla finish. Perfect fit!
-Chris
Snoopy FD
Dec 8, 2015 01:45 PM
sYnth.
Aug 19, 2015 06:27 PM
