Coolant buzzer going off for no apperant reason
Old Jun 14, 2004 | 06:45 AM
Rookie84's Avatar
Question Coolant buzzer going off for no apperant reason
Well, after an hour of driving, I noticed it started going off whenever I took a long-bending lefty. it would go off at about the end of the turn, so it doesn't go off right away as I turn left... it kept going off whenever when I took a long-bending lefty so it was driving me crazy for next 5 hours... I drove the car from OH to VA btw. I checked the coolant overflow tank and it was above full.... I really don't know what the problem is. Is this a common problem for FCs and what would be causing this? I didn't notice any change in water temp although the buzzer was going off. The temp was at consistant ~185F when I was cruising, and went up to about 190F when I got on it and almost redlined 4th... seems pretty normal to me. Any help would be appreciated. Thank you.
Old Jun 14, 2004 | 07:38 AM
SOIA's Avatar
Take A Look Around
Air bubbles in the coolant, my car started doing this a month or two before it died, I had to bleed the air out about once a week.
Old Jun 14, 2004 | 08:29 AM
introVert's Avatar
putting it down daily
^^ true ^^
Old Jun 14, 2004 | 08:41 AM
Relisys190's Avatar
REINCARNATED
Could be either air in the system or it's just slightly low enough to trip the level sensor. Could also be slightly low on oil as well being that the sensor is in the left side of the oil-pan, making a long left sweeping turn could cause the oil to just trip the sensor and buzzzzzzzzzz
The buzzer is for : Low Oil, Low Coolant, Over-rev.
Good luck.
Regards,
-Markus
Old Jun 14, 2004 | 08:48 AM
JackoliciousLegs's Avatar
haiO
Yeah, when you are doing any sort of serious turning, you're supposed to add near a quart of extra oil so that when stuff sloshes around, there's still enough to lubricate. With no extra in my tank, my buzzer went off consistently on a hard left during an autoX... well.. twice.. until i gave it some more earl...
Old Jun 14, 2004 | 08:50 AM
haiO
PS... can hear what I was talking about here: http://www.jmujack.com/album/?displa...3-13%2Flap.avi
[save target as]
Old Jun 14, 2004 | 01:36 PM
tntfox's Avatar
I had the same problem. I hope this is not the case for your car, but mine had leak in the seals between the combustion chamber and the cooling system. Exhaust gas was getting into the cooling system and creating hot bubbles. When the bubble would pass the sensor, the buzzer and light would come on. If I revved the motor a little, it would move the bubble by a little quicker and everything would go back to normal.
My local Mazda dealer did a litmus test on the cooling system and told me what was happening. I didn't believe it because they said the car usually has to overheat to cause this kind of failure. So I took the car to Rotary Performance in Dallas and got the same story.
The motor had 96,000 miles on it and the rest of the car is still in great shape so I had the motor rebuilt. I bled the cooling system several times before I faced the fact that I had a bigger problem. Hopefully this is not the cause of your problem.
Old Jun 14, 2004 | 02:04 PM
allforjesus06's Avatar
i love assembly lube
If you want a cheap way for the buzzer to go away, take the probe out and extend it down with like a soldered-on-wire or something. The probe is the nut beside the radiator cap. It's easier than trying to find the dang buzzer and taking it out... but it's just a cheap band aid. Not reccomended unless it's a track car, the buzzer drives you that crazy, and only do it if you don't have a leak or bad coolant seals.
Old Jun 14, 2004 | 02:27 PM
WAYNE88N/A's Avatar
check or replace rad cap
check water pump for weep hole leakage
check overflow tank tubing for cracks/holes
Old Jun 14, 2004 | 04:06 PM
Rookie84's Avatar
Thank you so much, guys! I'll check for most of the things you guys mentioned
BTW, does anyone know where I can get a cap for Koyo radiator? I think it's kinda messed up... do Koyo use different cap from stock rad?
Old Jun 14, 2004 | 04:25 PM
RexRyder's Avatar
Anyone think about the oil sensor?
Long left hand turns... Buzzer goes off... Low oil....
Sheesh..
Old Jun 14, 2004 | 10:58 PM
haiO
Sheesh..
Old Jun 14, 2004 | 11:04 PM
Rookie84's Avatar
Well, it was coolant buzzer because add coolant light in the center light cluster or whatever it's called came on with the light.
Old Jun 14, 2004 | 11:13 PM
neptuneRX's Avatar
Mazda4Life
if it only happens when your autoX I wouldn't worry about it too much
Old Jun 14, 2004 | 11:22 PM
Rookie84's Avatar
Huh? I don't autoX my car... It happened to me several times on the highway when I was coming back to VA from OH.
Old Jun 15, 2004 | 02:18 AM
RexRyder's Avatar
Sheesh..
umm i never posted this. I was at work at 1030. And i don't say "sheesh" I say ****, or ****. I'm gonna change my password
Old Jun 15, 2004 | 03:28 AM
Thats great
My car had a similar problem and it turned out to be a crappy soldering job on the sensor wire that runs to the coolant level sensor probe. Quick and easy check, just pull the wire lightly and make sure its on there good. Hope this helps
Old Jun 15, 2004 | 04:11 AM
NZConvertible's Avatar
I'm a boost creep...
Nobody's corrected the obvious mistake yet...
The low coolant warning is for the radiator level, not the overflow tank level.
Old Jun 15, 2004 | 08:41 AM
jon88se's Avatar
Eat, sleep, work, mod.
It's a common FC problem...often times the sensor/wire gets loose and trips the buzzer/light. Make sure the connection is nice and snug, 5 minutes after the buzzer goes off you would know if something was really wrong.
Old Jun 15, 2004 | 08:43 AM
J-Rat's Avatar
Alcohol Fueled!
I had to rewire a big section of that line on an FC that I was working on.
Old Jun 15, 2004 | 11:57 AM
Dltreezan's Avatar
My Bick is Digger
ah so thats why...I knew to be checking the oil sometime soon and i keep putting it off and this buzzer has been getting on my nerves when i take the left turn.....hmmm....so it isnt just a coolant buzzer...maybe i should put some oil in . Thanks guys
Old Jun 15, 2004 | 12:04 PM
NA2TurboProject's Avatar
You most likely have exhaust getting into the coolant system.
Old Jun 15, 2004 | 12:11 PM
jon88se's Avatar
If doesn't have exhaust getting in the coolant unless his overflow tank is spilling out and or the car bubbles/spits coolant when started with the rad cap off.
JoesFC
Oct 5, 2015 08:10 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
sinistersam
Sep 13, 2015 07:17 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
