Heim/Rod ends and aluminum hex tubing
Old Jun 13, 2004 | 12:06 AM
eyecandy's Avatar
I would like to make some adjustable toe and camber links for my FC and I am having a hard time finding metric heim/rod ends and aluminum hex tubing... Any suggestions?
Can you use standard sizes or will there be to much play between the bolt and rod end whole?
Old Jun 13, 2004 | 08:54 AM
Re-Speed.com's Avatar
Most people use step bushings. One on each side of the rod end that will change it to a smaller metric size as well as fill the gap between the rod end width and the bracket width. www.aedmotorsports.com would be a good source for the ends and the tubing.
-billy
Old Jun 14, 2004 | 09:29 PM
eyecandy's Avatar
Are there any other good places?
Old Jun 24, 2004 | 05:07 PM
eyecandy's Avatar
I finally got word back from them and they said they di not carry and step bushings or reducers....
What do you guys feel as an adequate rod end?
Old Jun 24, 2004 | 07:16 PM
I thought they did.........
I can make the step bushings if you let me know what you need
-billy
Old Jun 24, 2004 | 09:30 PM
eyecandy's Avatar
Well as of right now I am not 100% sure of what I need. I know there has to be some where I can find them, Rotary Extreme and Mazdatrix uses them......
Old Jun 25, 2004 | 08:58 AM
Most of the time they are custom made. There are to many variables for them to be 100% off the shelf.
I did a little drawing. You can take this to any machine shop and they can make them for you. You will need 2 of these per rod end. They fit inside the rod end on both sides and change the diameter as well as fill the bracket width.
Here is a quick image of what you need:
http://home.comcast.net/~respeed/spacer.jpg
Here is a PDF file so you can read and print it out:
http://home.comcast.net/~respeed/SPACER.pdf
Old Jun 25, 2004 | 10:44 AM
AWR makes everything you need, I have the camber links, and the Toe links, not cheap, but tried, and true. These are made for the FC, and proven on many EP cars. Here is the link http://www.awrracing.com/pages/rx/rxsusp.html
Carl Byck
Old Jul 5, 2004 | 02:54 AM
Carl Byck
If anyone needs any of these AWR parts please contact me and we will work out a deal.
Josh
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
NotMrButts
23
Sep 15, 2015 09:46 PM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
