Failed Illinois emissions test
Old Nov 10, 2001 | 11:26 PM
mecman's Avatar
Question Failed Illinois emissions test
HELP- My '93 Touring just failed the Illinois emissions test. Both Hydrocarbons and carbon monoxide were twice the allowable limit. The car is stock with the exception of a PFS Intake. I just completed most of the reliability mods and had new plugs and wires put in this summer.
Anybody have any suggestions on how to get it to pass?
I was thinking of a DP and High Flow cat next year but my MAZDA RX7 mechanic said he did not think it would pass emissions. Anyone in Illinois have similar problems?
I can't imagine not being able to drive this baby!!
Old Nov 11, 2001 | 04:49 AM
billyrohm's Avatar
Man who sold his 7
hows your air pump? Did you change the oil before the test? Checked your vacuum lines?
Old Nov 11, 2001 | 01:55 PM
alwan16's Avatar
how's your exhaust smell? if it smells funny then is the air pump working? no holes or cracks in the rubber hose going from the airpump to the acv? a crack would give you those symptoms because not enough air would get to the catalytic converter at idle.
Old Nov 11, 2001 | 09:51 PM
mecman's Avatar
Thanks for your replies.
The air pump seems to be functioning properly. No funny smells from the tail pipe.
The car has 1800 miles since the last oil change. I was going to try an new oil change and to see if any gas additives are sold for emissions testing.
The vacuum hoses visually seem o.k. from what I can tell. My boost gauge says I get great boost (about 13-14 lbs.@2500 rpms) during WOT. The Air/Fuel meter reads o.k. maybe slightly rich for a second or two during WOT. I therefore assume there are no vacuum or hose problems.
Any other ideas or expiriences??
alexdimen
20
Oct 23, 2015 01:50 PM
ZacMan
Sep 19, 2015 09:20 PM
