Fd rims on Fc
Old May 28, 2004 | 04:06 PM
BOOSTED Vert
Fd rims on Fc
I got a question... Im buying some blitz z1's from someone who had them on an fd... I always liked these rims and now I have a good chance of owning them... Although he pointed out a good question.. Will they fit on my car... I have a vert and his rear offset is +22. I just want to make sure it fits before I buy these pretty expensive wheels...
Old May 28, 2004 | 04:35 PM
RETed's Avatar
We also need the width.
Judging from the offset, it sounds at least like a 9" wide or wider wheel you're talking about.
-Ted
Old May 28, 2004 | 04:54 PM
BOOSTED Vert
lol sorry about that its 18x10
Old May 28, 2004 | 05:18 PM
BOOSTED Vert
think it will fit ?
Old May 28, 2004 | 05:33 PM
fc3seeker's Avatar
T2 Noob.
Jeez, thats one wide rim
Old May 28, 2004 | 07:58 PM
BOOSTED Vert
Old May 28, 2004 | 10:46 PM
mazdaspeed00's Avatar
For Sale
it will not fit unless your FC has a widebody conversion
Old May 28, 2004 | 11:06 PM
BOOSTED Vert
will not fit in what way ???
Old May 29, 2004 | 02:00 AM
RETed's Avatar
It won't physical fit in the stock fender wells, either front or rear.
Unless you're the type that would try and stretch a 255 wide tire on a 10" wide rim...
-Ted
Old May 29, 2004 | 02:41 AM
BOOSTED Vert
-Ted
What if I roll out the fenders??? I know turboIIrudeboy has some wide tires in the back, that stick out a bit, I want to know what his offset and size is.... O and the front arent the same offset.. Im more worried about the back than the front..
Old May 29, 2004 | 01:09 PM
BOOSTED Vert
Old May 29, 2004 | 04:14 PM
neevosh's Avatar
The Dude Abides
Compared to a stock 16x7 +40 wheel, an 18x10 +22 is going to stick out about 2 1/8 inches. You'll probably have to pull the rear fenders out to cover. You might be able to get away with just rolling the fenders and some negative camber, but you'll be limited on the tire size.
Old May 30, 2004 | 04:11 PM
RETed's Avatar
You cannot roll the rear fenders.
If you figure out how to do that, please tell me too!
-Ted
Old May 31, 2004 | 01:46 PM
neevosh's Avatar
The Dude Abides
Why not? Is it too thick? I haven't tried yet, but looking at it it looks possible. A heat gun and a hammer should do the job.
Old May 31, 2004 | 02:02 PM
BOOSTED Vert
Thanks, I already figured that out by how it fits on the fd... it sticks out like about an inch, or 1/2 inch... I had 18x10's when I bought the car but didnt know what the offset was.... and it fit awesome... I have the gxl stockers and it tucks in the back... Thanks though I was planning maybe to get some bodywork in the back to widen the rear out a bit and purchasing some front fenders...
Old May 31, 2004 | 04:46 PM
RETed's Avatar
The stock FC rear fenders are double wall, and not the thin stuff that the front fender is made out of.  basically, you're going to have to cut and weld the flare in pieces to do it right - this is the only way I know how, so if you got an alternate EASIER method, please share!
-Ted
Old May 31, 2004 | 05:08 PM
BOOSTED Vert
ted you know of any wide kits that arent that ricy looking and actually widen the back a little but in a clean way??? Im not looking to run 14" wide rims in the back so the mariah kit is outta the question... I just want something thats a little wider and can compliment the corksport front fenders...
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
Rotary12Ahead
Oct 29, 2015 03:16 PM
NickNac113
13
Oct 1, 2015 09:25 PM
