No power to ECU or Odometer - Everything else has power. Car Won't Start.
Old May 27, 2004 | 12:40 PM
dhahlen's Avatar
FD Under Construction =P
Alright...
ECU (PowerFC w/Commander) and/or Stock ECU won't come online.
Odometer doesn't show up.
Everything else has power...dome lights, radio, headlights, dash lights, windows, etc.
I checked my fuses, my relays, and the ECU ground. I reseated the connections under the UIM. And still no luck.
The car will not start... I was backing up out of a parking lot and the engine just shut off.
I swapped all relays with known good ones, and swapped fuses, main fuse is fine.
I'd like to check all the main wires to the ECU, there are 3 power wires I believe.
1.) Black with white stripe (+12V when Ignition is 'ON')
2.) Blue with red stripe (Constant - for memory storage, always +12V)
3.) Blue with white stripe (Connected to the room fuse)
If this is incorrect let me know. This may be a grounding issue but I do not know where to start.
Old Jun 10, 2004 | 03:03 AM
dhahlen's Avatar
ignition wiring - wire was completely toast behind the ignition switch. Replaced it and it's all good.
Old Jul 13, 2004 | 10:06 AM
SomeGuy_sg's Avatar
Sweet ...
Old Nov 15, 2004 | 10:41 PM
springhill93rx7's Avatar
Newbie
having same problem, 93 touring , but vehicle runs for about 5 minutes then odometer shuts off and so does car , odometer comes on after about 10 or so minutes then you can start back up and then it wil die again, already replaced ignition switch i guess that doesnt solve the problem , which wires did you have to replace by the ignitoin switch to fix problem and where did you get them , was it a harness or just splice the wires back to gether, please respond thankx
ChrisRX8PR
Aug 21, 2015 01:56 PM
gtcd
30
Aug 19, 2015 02:44 AM
rx7brandon
Aug 16, 2015 10:55 AM
