new engine
Old Nov 8, 2001 | 10:46 AM
Roadracing7's Avatar
new engine
I'm breaking in my new engine and turbos. I'm going the no boost, 3k rpm limit theory until after 500 then increase boost and rpm slowly. Well anyway, I reached 500 miles yesturday and changed the oil. I have an R1 so it holds more oil, I drained the old oil and put in about 5.5 new quarts. When I measured what came out of the pan, it was only 4. So needless to say, I overfilled it.
Whenever I take a turn or stop on a downhill slope, it smokes a lot of blue at idle. It scared the crap out of me, I thought it was turbos leaking. What do you guys think? I have heard that I might have a bad check valve from the crankcase to the Upper Intake Manifold, lemme know your thoughts. Thanks.
Richard
Old Nov 8, 2001 | 05:28 PM
I think ur best bet is to take out the xtra 1.5 qts of oil. Not sure about these motors but in a standard piston motor Ive read its not good to overfill..........it causes foaming or somethng like that I believe and that effects flow.
Nice car btw!
Old Nov 8, 2001 | 08:30 PM
Well, I believe the problem is fixed. Turned out to be a check valve. When I pulled off the vaccum hose, there was a loud 'whoosh' noise, there was a lot of pressure in there... Took out the valve, and it was clogged, so I'm popping in a new one tomorrow to hopefully remedy the high oil pressure and blue smoke in the exhaust. L8R
Richard
Old Nov 9, 2001 | 07:01 PM
user 84205's Avatar
one more thing
Hey bro,
I had that happening too, but I had all colors or smoke.
I took it to my mechanic, he said no big deal just take out the
extra oil in the oil change. BUT he said the pressure can get
really high, and **** other **** up. Mostly O-rings, but checkvalves and **** too. GOOD LUCK
Microtech
30
Apr 23, 2016 06:37 PM
Wicked93gs
Aug 23, 2015 10:14 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
