Nitrous
Old May 25, 2004 | 09:10 PM
BIG J MIXALOT's Avatar
SHSHSHA POCKET SAND
Talking Nitrous
has anyone put nitrous in a 12a stock motor
Old May 25, 2004 | 10:02 PM
V8kilr's Avatar
me me me me
lol
Its was a custom built kit, wetshot got the parts off ebay.
sprayed 75 shot (roughly 75hp) worked good.
I just copyied the parts list from the NOS site, but got the parts cheaper on ebay.
Old May 25, 2004 | 10:27 PM
perfect_circle's Avatar
*hi-jacks thread* would it be safe to run a wetshot on a blowthrough. its gonna be a 12a, with a modded nikki, and an s5 turbo.
Old May 25, 2004 | 10:31 PM
FB II's Avatar
safe??? it depends! HAHAHHA, maybe a 50 shot? try it and let us know what happenED. hahaha, i feel you may only get one shot!
-zac
Old May 25, 2004 | 10:37 PM
i'll take that as a no
Old May 25, 2004 | 10:38 PM
RotaryRyan's Avatar
DSM
lol When someone says "try it and let us know what happens", its usually not a good idea.
Old May 25, 2004 | 10:42 PM
thats pretty much what i got out of that
p.s.ryan is that an apc muffler?
Old May 25, 2004 | 10:44 PM
RotaryRyan's Avatar
DSM
hey perfect circle, what is your avatar?
Old May 25, 2004 | 10:49 PM
i dunno, i reached 100 posts, so i went to like google or something, and searched wankel in the photo part,then i found this one, the one like....i supose it is like a concept..er..somthing.
Old May 25, 2004 | 10:50 PM
FB II's Avatar
no, i think it's a mock of a shamrock stuck in a can? i'm so fat it roX!
-zac
Old May 25, 2004 | 10:54 PM
after looking at it for a while, besides the intake and combustion part, i dont even think it would work, because it couldnt rotate completely,lol.
Old May 25, 2004 | 10:55 PM
http://www.citroen.mb.ca/citroenet/html/w/wankel.html
heres the site
Old May 25, 2004 | 10:58 PM
FB II's Avatar
yea, it failed
Old May 26, 2004 | 01:51 AM
kettlman's Avatar
THE ONE. THE ONLY!
looks to me like the gears of a oil pump. thats my answer.
anyways i want to nos mine also in awhile. yet i'm not quite stock. let me know how it works. i won't do it till i get a supercharger or turbo.
Old May 26, 2004 | 07:16 AM
V8kilr's Avatar
Dry shot no, wet shot you could most likely get away with a 50 shot depending on how much boost you will already be pushing into the motor.
THe only real problem you will run into is that the exhaust ports wont be able to handle everything comming out .
With a big port job you could get away with more, what I would do is setup your turbo to run less boost when using the nitrious.
Im no turbo or nos expert but I would say you could get away with 5-8 psi boost and 50 shot off a wet system.
But what you have to weigh out is if the extra 50 hp is worth how much hp the extra psi of boost you would normally be getting worth it?
another good thing about wet systems is that you dont have to play with your air intake or fuel systems at all, you just run a seperate fuel line for the system and thats it, no running rich to compensate for when you might spray like a dry system.
Personally I think nitrious (wet system only) is a much more reliable and econmical way of adding horse power over both a turbo and a supercharger.
I say reliable as in how long your motor will last, in fact I even read an article from NOS that adding a 25-35 shot off a west system when used properly will not harm or shorten the life of your engine at all, and (get this) a 25 shot is actually beneficial in some ways to the internal components of an engine.
I am only rambling on cause I know alot of people will shoot down nos because of all the horror stories, but 9/10 of those are dry systems, and the other 1/10 are usally just dumb asses that didnt read the instructions on when to/when not to spray, how to prep your engine, and what grade of fuel to run.
theres my 2 pennies
Old May 26, 2004 | 07:25 AM
V8kilr's Avatar
BTW here is the kit I copyied.
http://store.summitracing.com/partde...rt=NOS%2D05030
Here is another one which is basically the same thing
http://store.summitracing.com/partde...S%2D05030%2DFI
I built mine for around $350
The kit starts out at 75 shot which is what I sprayed, I think it goes up to something like 250 shot
I only sprayed 75 because I had a dying motor, if the motor was in better condition I would have felt very confident with 100 shot, with a street port I would have felt very confident in pulling off a 125 shot and maybe even 150, but thats a big maybe.
Old May 27, 2004 | 01:06 AM
kettlman's Avatar
THE ONE. THE ONLY!
i've been talkin about nos to a few reliable people. they've told me that unless you got clearanced housings it is not advisable to go over 100. 75 is recomended. just to let you know.
Old May 27, 2004 | 08:52 AM
Xavier8's Avatar
Never satisfied
seems like to me that putting a 35-50 shot on a holley carbed motor would be extremely easy, as all the fitting to go between the carb and intake are readily available. I also think a streetported motor could handle the 50 shot in stride, as long as it was a wet shot as previously mentioned. Maybe I will try this for my streetported 12a with 465 holley, as an extra 35 hp in my 1500 lb car would make it a giant killer. I wonder if barnetts wil even sell me jets small enough for a 35 shot. hehe.
Old Aug 5, 2004 | 01:43 AM
Xavier8's Avatar
Never satisfied
Will probably buy a 75 shot kit tommorrow for my car. Found an awesome deal and shall see if it pans out.
Old Aug 5, 2004 | 04:37 PM
Mills's Avatar
procrastination engineer
It's called a gerrotor-it's what 99 and newer Jeep Grand Cherokees use in their axles to allow all the torque to be transmitted to one wheel (as opposed to one axle).
Old Aug 5, 2004 | 08:38 PM
RotaryRyan's Avatar
DSM
Nope. I dont know what brand it is. Got it on ebay. Its an 8 inch diameter strait-flow. I like the way it sounds.
Old Aug 6, 2004 | 11:21 AM
for how much, like $0.50
Old Aug 6, 2004 | 11:46 AM
Xavier8's Avatar
Never satisfied
Wow, this thread is way off topic. I'll bring it back to nitrous. I purchased a TOP SHOT NOS nitrous kit for 300 dollars new with everything included. This setup injects nitrous and gas directly into my holley 465 by a nozzle system above the carb. I will be running a 10 lb bottle behind the passenger seat so I can turn it on while driving if needed. The smallest shot I can use with this system is a 75 shot, so I will put in those jets, bring the timing back 3 degrees, replace the unleaded with premium, and go ahead and try it. From extensive searching on this forum, there are plenty of people who have used this amount on their 12as. Nobody provided any jetting reccommendations though. Are there any out there? I will pm judge ito, maybe he can help.
Old Aug 6, 2004 | 12:56 PM
RotaryRyan's Avatar
DSM
$20
Old Aug 6, 2004 | 01:04 PM
1984se's Avatar
Ryan
NEVER USED SO I COLDN'T tell you guys how it was, IT FOR SALE THOU ! !
-Ryan
