rear end trouble...advice?
Old May 24, 2004 | 03:03 PM
Sk8r_dude's Avatar
Zoom - Zoom...
my car sounds like a washing machine when i drive. i thought it was the rear end (LSD from a GLS) so i checked and there is play in the drive shaft. Is there any remedy for this, or am i looking at replacement? anyone encountered this? i have a LSD from a se, anyone wanna tell me what'd be involved in the swap? i have the gsl-se rims, but i dont wanna change my rims, cause they have new rubber and the se rims dont not to mention they wouldn't match the front rims...advice? anyone? help?
Old May 24, 2004 | 03:51 PM
680RWHP12A's Avatar
it could be a wheel bearing, have you checked them?
all rear ends have play in the rear ends, dont worry about that...
the se lsd is a easy swap, pull the axles, driveshaft, remove all 12mm bolts holding the pumpkin it and remove ,.... assembly is the reverse, its pretty easy
Old May 24, 2004 | 03:56 PM
Sk8r_dude's Avatar
Zoom - Zoom...
the pumpkin will line up ok? arent the axels different sizes? how long will it take?
1984se's Avatar
Ryan
what do you mean by free play?
You need to check the fluid in the diff and in the tranny as well.
use synthetic fluid, gear oil 75/90, 80/90 either or, and you need to get the LSD additive.
-RYan
Old May 24, 2004 | 03:58 PM
Sk8r_dude's Avatar
Zoom - Zoom...
i just replaced the front wheel bearings too.
Old May 24, 2004 | 04:00 PM
680RWHP12A's Avatar
all 84-85 models have the same size axles....the only difference is the se model axle shafts have a different bolt pattern
Sk8r_dude's Avatar
Zoom - Zoom...
the oil in the diff is full, and it looks clean.
Old May 24, 2004 | 04:33 PM
680RWHP12A's Avatar
what about the rear wheel bearings......
Old May 24, 2004 | 05:32 PM
Sk8r_dude's Avatar
Zoom - Zoom...
ill check em.
Old May 24, 2004 | 05:43 PM
bouis's Avatar
I've got some noise coming from my rear end also. Increases with speed. It's an '85 with drum brakes. Is there a quick way to inspect/check the rear wheel bearings?
Old May 24, 2004 | 07:24 PM
wwilliam54's Avatar
it WILL run
where are you in MS bouis?
a good way to check the bearings is to jack up one rear tire and take ti off, put one lug bolt back in so you can turn the axle
turn it slowly, if you hear a scraping sound coming from right behind the drum/disk the bearing is bad
do this for both sides
Old May 25, 2004 | 12:23 PM
bouis's Avatar
Hatttiesburg. But I'm currently stuck in Poplarville 'till I can get my car going. I'm rebuilding the front suspension, but I can't do anything with one balljoint and one tie rod end. Thanks AutoZone!
Old May 25, 2004 | 12:25 PM
wwilliam54's Avatar
it WILL run
i have a tie rod end you can borrow
i live right up the road in ellisville
Old May 25, 2004 | 12:42 PM
cpt_gloval's Avatar
KARATE EXPLOSION
i've heard axle bearing failure is pretty common on these cars. i just had my passenger side axle bearing replaced. cost me $100 to have it done for me (i don't have a press).
Old May 25, 2004 | 01:37 PM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
Re: rear end trouble...advice?
Have you pinpointed the noise?
If it's coming from the rear of the car, have someone drive the car and hop in the back and have a good listen to see if it's coming from a certain side. From your description I would lean towards a rear wheel bearing. If you decide to change the rear wheel bearing, I would put in that LSD from the GSL-SE that you have, since you already have the axle pulled.
Old May 25, 2004 | 02:46 PM
bouis's Avatar
Thanks wwilliam54 but it'll be here tomorrow. Like I said, I'm currently in Poplarville which is a ways down, but I'll be back in Hattiesburg this weekend. If you wanna meet up sometime, that'd be great. I'm sure you'd like to give my new CP rack & pinion a try .
Old May 26, 2004 | 04:11 PM
wwilliam54's Avatar
it WILL run
lol
get on AIM i use the same name
Th0m4s
Feb 26, 2019 02:04 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
