Do I have proper fuel to power turbo ? (Specs inside)
Old May 24, 2004 | 12:07 AM
Gibenstein's Avatar
Well I am going to pickup a car that has a single turbo conversion greddy td06. Anyways the car is running on stock injectors and stock fuel pump . Is this safe ? Or should I replace with larger ?
Old May 24, 2004 | 12:13 AM
MrRx's Avatar
Rotary on a budget
umm. hell no.... just get the Rx7store.net fuel upgrade package....
your going to need larger injectors, a powerfc to run them, aftermarked rails, regulator, and pump.
the only way that would be safe, is when your not boosting
Old May 24, 2004 | 12:16 AM
Gibenstein's Avatar
Heres what it gots
TDO6 Greddy Turbo Kit (pulleys,downpipe,manifold,wastegate)
24row polished gr Greddy Intercooler kit all polished
Custom Mid Pipe polished
Apexi N1 Exhaust
Apexi Power Fc with Commander
PWR polished Radiator
Old May 24, 2004 | 12:30 AM
xxfetusmanusxx's Avatar
ricankilla!
i agree with MrRx! you need more than a pfc to fuel all that!
Old May 24, 2004 | 12:45 AM
MrRx's Avatar
Rotary on a budget
with a good fuel system and good tuning you gonna be puting out like 400hp
heres a link with everything you need
http://www.rx7store.net/index.asp?Pa...ROD&ProdID=578
Old May 24, 2004 | 12:48 AM
Gibenstein's Avatar
Ok I can run a supra pump and step down on the kit correct ? So I will run 1600's , aftermarket secondary fuel rail , FPR , and a supra pump ? This sound adequete? I will leave my primarys stock.
Old May 24, 2004 | 11:50 PM
Gibenstein's Avatar
Ok guys what I want to know will it be safe to run it home . It is pushing 10lbs which I have read is safe. I will upgrade my fuel system as soon as I get it back to my house. Thanks for yalls replys.
Old May 25, 2004 | 10:39 AM
Gibenstein's Avatar
Bump its pushing 8-9lbs of boost as is .
alphawolff
Nov 17, 2015 05:57 PM
cam_7779
Aug 18, 2015 07:48 AM
