simple O2 sensor question (not WB)
Old May 23, 2004 | 11:36 PM
BOTTLEFED's Avatar
Freudian slip
I did a search and did not find my answer, so here goes...
I need a new oxygen sensor (mine broke while pulling the motor) and I was wondering if there is a better replacement sensor/brand than the stock one.
I cannot afford a wide-band right now. I just want the best replacement.
TIA
Tim
Old May 23, 2004 | 11:58 PM
Androidmj's Avatar
u can get a cheaper o2 sensor if you buy the bosch universal o2 sensor...i think you just need to attach the wire to it....do a search for bosch sensor and you should find some good stuff
Old May 24, 2004 | 09:09 AM
saxyman990's Avatar
Place your ad here...
Use a Bosch universal (Part number 11027), it's less than $18 and available at any autoparts store. It's the exact same sensor, the only difference is that it doesn't have the OEM connector on the end of the wire. The only thing you have to do is cut the connector off your old one, and crimp it on to the new one.
Old May 24, 2004 | 09:47 AM
Toadman's Avatar
Nomad Mod
It comes with anti-sieze compound and a small piece of shrink tubing to cover the new connection. You can heat-gun it or use a bic lighter to get it to seal.
Old May 24, 2004 | 11:04 AM
BOTTLEFED's Avatar
Freudian slip
Thanks, I just thought there might be a aftermarket one that was better than stock or something. I think the one that is one there is a Bosche since it is spliced to the connector.
Old May 24, 2004 | 11:54 AM
dubulup's Avatar
development
86 escort has a 3 wire heated O2. $26 or so...
Skeese
65
Mar 28, 2017 03:30 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Snook
Aug 15, 2015 08:18 AM
zuesskroph
Aug 13, 2015 06:05 PM
