FD boosts to 7psi when set at 10psi on PFC.
Old May 23, 2004 | 02:36 PM
BATMAN's Avatar
Not sure if this is a PFC issue or FD, but I'll just post in here.
Basically, my PFC is set at the stock boost of .8/.7 bar.
The most boost that I am getting is right around .5 bar which is 7~ psi.
What could be the problem?
vacuum?
solenoid?
main cat clogged up?
Old May 23, 2004 | 02:40 PM
clayne's Avatar
PV = nRT
WG / PC control line pills absent.
Old May 23, 2004 | 03:33 PM
wickedrx7's Avatar
I second that motion...
Old May 23, 2004 | 04:09 PM
seandizzie's Avatar
Are your duty cycles set correctly
Old May 23, 2004 | 04:44 PM
BATMAN's Avatar
the only thing that i changed was push the secondary from 850 cc to 1300cc when i just installed the new secondaries......
Old May 23, 2004 | 05:30 PM
COsborne's Avatar
My Custom Title > Your's
I'd check the cat and pressurize the intake after the turbo and listen for leaks.
Old May 23, 2004 | 05:32 PM
cloud9's Avatar
The bomb is in the toy!1!
Top Answer: 1
I would think cat
Queppa
Nov 18, 2024 03:47 AM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
Snook
Aug 15, 2015 08:18 AM
