my fuel pump doesnt come on
Old May 22, 2004 | 05:20 PM
lemonade's Avatar
You can choose this?
ive got a holly fuel pump, everything was working fine untill my battery died after i changed alternators. i charged the battery, cleaned the connections, and tried to start it, it would fire. then i notice i cant hear the fuel pump. its not coming on. does anyone know why this could happen? or how i can fix it?
Old May 22, 2004 | 05:41 PM
lemonade's Avatar
bump
Old May 22, 2004 | 05:55 PM
BrianHeston's Avatar
Beware Of Squirrely Wrath
Have you checked the fuse, the connections under the driver's side bin, and the connections at the pump?
Also, try just running wire straight from the battery to the pump, just as a test.
Old May 22, 2004 | 05:59 PM
lemonade's Avatar
i checked all the fuses, are there connections visible if you take the bin out? where can i reach the pump?
Old May 22, 2004 | 06:00 PM
dole2000's Avatar
ARE YOU GETTING POWER TO THE PUMP? I'VE HAD TO RUN A HOTWIRE TO THE FUEL PUMP WITH AN OFF/ON SWITCH. THE WRE IN QUESTION COMES OFF THE STARTER AND IS REGULATED BY THE IGNITION SWITCH.
THE PUMP IS UNDER THE CAR NEEAR THE REAR DRIVER SIDE WHEEL WELL. AT LEAST THE STOCK ONES ARE.
Old May 22, 2004 | 06:18 PM
lemonade's Avatar
what could have happened when i:jump started it. took the alternator out. changed the belt. tried to jump start it. took the battery out. cleaned the connections. got it charged. put it back in. turned it over. it was probably caused by one of those things. i dont see how a connection could get messed up by these. the fuses looked fine. one thing i didnt understand. there was a cruise fuse, with a wire bent over it, so it was in contact with some of the metal.
Rotospectre
Mar 28, 2018 03:33 PM
ChrisRX8PR
Oct 18, 2015 04:01 PM
