This smoking problem getting confussing
Old May 22, 2004 | 12:30 PM
dnlloran's Avatar
Question This smoking problem getting confussing
Sorry guys, I did a research and can't really find anything that matches my problem. I have an 84 rex that smoked really bad all the time, I pulled it into the garage and drained the antifreeze and oil. I have no oil in the antifreeze and no antifreeze in the oil. I do however have a very strong gas smell in my oil snd it is very thin. I found that one of the coil wires wasn't connected as well as one of the spark plug wires. I pushed them back on and found that the distibuter nut was missing and replaced it. Put new fluids in and pulled it out of the garage still smoking. back into the garage checked omp and even pulled it off and broke it down and put it back together. once again pulled the rex out of the garage, would idle but very little smoke. I messed with the timing abit and got it to idle still very little smoke. I then messed with a couple of screws on the carburator smoke went away, I took it for a test drive, did fine on city streets but when I got out on the highway and punched it, smoke bellowed out the exhaust. returned home. Now I have no smoke at idle and low rpms but as soon as I reach 4500 rpms smoke. Please let me know if this is an easy fix, If not, the engine is going to be pulled and rebuilt.D.
Old May 22, 2004 | 12:36 PM
rototiller1's Avatar
Inspector, Falcon Jet
U answered your own ?
Old May 22, 2004 | 02:13 PM
Slammed_GSL's Avatar
You got some bypass on your oil seal rings, these are the 2 rings on each side of the rotor that keeps the oil in the center of the rotor for the eccentric-shaft lubrication and away from the compression/combustion/exhaust rotor faces.
The higher rpm's build preassure in the internal oil chamber(oil pressure is higher) and these seals will pass oil if they are failing, debris under them or the seal springs slipped or misaligned. If your compression is good you can get a seal and gasket kit and rebuild the engine to freshen it up. Just one idea.
Old May 22, 2004 | 10:25 PM
dnlloran's Avatar
forgot to mention compression is at 60 psi or 400 kpa in all four areas, not sure if this is good or not. And why was there so much gas in my oil?
Old May 22, 2004 | 10:48 PM
85rotarypower's Avatar
love the braaaap
It confuses me why people smoke too.
Old May 22, 2004 | 11:15 PM
faye x7's Avatar
brilliantly stupid
What he said is most likely what's happening in your engine. If your oil seals in the engine are failing you're bound to get more gas mixed in with your oil.
Old May 23, 2004 | 11:55 AM
dnlloran's Avatar
Thanks for the replies. Into the garage here we go for how long no one knows, and if I don't screw things up, and with a 'lil bit of luck, she'll be cruising the roads and having fun by the loads. D.
qqqqball
11
Oct 9, 2015 07:06 PM
ZacMan
Sep 19, 2015 09:20 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
