White smoke- from the turbo??
Old May 22, 2004 | 02:39 AM
The Spyder's Avatar
Never give up!
Could this be?? White smoke caused by the turbo?
Its not a coolant seal from what I can tell-
(refer to this thread https://www.rx7club.com/showthread.p...hreadid=307766)
Im still waiting to see about if the TID is slick with oil.
Old May 22, 2004 | 03:04 AM
wwilliam54's Avatar
it WILL run
s4's have a side plate with a water seal known to crack and leak
Old May 22, 2004 | 10:00 AM
IRPerformance's Avatar
Sponsor
Is the smoke coming form the turbo area itself or out the tailpipe?
Old May 22, 2004 | 02:19 PM
The Spyder's Avatar
Never give up!
The smoke only occurs after boost- out the tail pipe-
I had the owner run all the tests of how to check for a bad coolant seal and its not that.
Im almost positive its the turbo- someone I know cracked his T04 and the synthetic caused white smoke.
Im going to look at the car soon, if it is the turbo- Ill buy it- if its a water seal- cant afford the rebuild.
Old May 22, 2004 | 03:49 PM
Digi7ech's Avatar
I break Diff mounts
This is kind of what mine is doing right now.
Here are some pics of my hotside(S5 turbo) after I removed it.
It would leak oil so bad that it dripped through the hotside and burned off in the engine bay along with threough the exhaust.
This is a rebuilt turbo with only 4 hours of idle time on it(NO BOOST TIME!)
Does anyone have a clue to why it would do this?
The oil return is fine.
[img]
Old May 22, 2004 | 09:46 PM
The Spyder's Avatar
Never give up!
Would someone explain WHY oil would be found in the TID? People have had me check- what if its like the hot side leaking?
Old May 22, 2004 | 10:09 PM
The Spyder's Avatar
Never give up!
streetlegal?
Mar 17, 2022 02:46 PM
cristoDathird
28
May 30, 2019 08:47 PM
