Oil Cooler Upgrade.
Old May 20, 2004 | 08:40 PM
Droptopdsm's Avatar
Oil Cooler Upgrade.
To those who have done oil cooler upgrades, what did you upgrade with, and what were the results? Im looking at doing track work with a Bridgeported, TA-51 Turbo. How will the stock coolers cope?
Old May 20, 2004 | 08:51 PM
180sx-x's Avatar
Zoom-ing Goon.
wat model do u have? most ppl that dont have the r1/r2 usually upgrade to the r1/2 twin oil cooler setup.
Old May 20, 2004 | 09:10 PM
rynberg's Avatar
I recently installed the Rotary Extreme dual 25-row kit. I have a track day on the 28th and will post my review then. I can say that the kit is WAY OVERKILL for street driving. I haven't been able to get my oil temps to budge over 180F yet in street driving.
If you are planning on regularly tracking the car in 90+F weather, I would get either the Crooked Willow or Rotary Extreme oil cooler kits. If you will only occasionally be running events in weather that hot, I would stick with the stock dual coolers and see how your temps are.
Which brings me to my next question, do you have an oil temp gauge?
Old May 21, 2004 | 02:48 AM
ooEfiniRx7oo's Avatar
I just read about upgrading the oil cooler on the Rx7 magazine and it said to use the FC oil cooler. Its much bigger than the FD's oil cooler and also very effective and cost saving.
Old May 21, 2004 | 03:08 AM
rynberg's Avatar
I don't see how. But if YOU want to fabricate mounting brackets and figure out how to run the oil lines, go ahead. People sell their R1/R2 dual cooler setup on a regular basis for $400 or less.
Old May 21, 2004 | 09:12 AM
Droptopdsm's Avatar
92 Efini. I have the dual coolers.
I plan on tracking the car at least once a month.
No, I havnt installed a oil temp gauge. The car was completely stock before going in for the build. Was just curious as to how far people have pushed their cars out on the track with stock coolers/upgraded coolers and what their thoughts on the matter.
Ok. I will be keen on seeing your results.
Old May 21, 2004 | 09:56 AM
zmarko's Avatar
shoo shoo retarded flu!
This makes me nervous because mine regularly hang around the 210*F range during daily driving (city driving).
Old May 21, 2004 | 10:21 AM
FormerPorscheGuy's Avatar
Yes it is for sale.
The "efini" was never issues into the US market. To let you know, you have a regular RX-7 like the rest of us.
My advice to you is to keep your stock dual coolers and get a Temp gauge. The stock duals work well and should suffice for what you want to do.
Old May 21, 2004 | 10:51 AM
Zero R's Avatar
Just in time to die
No need to be nervous 180 is a little on the cold side, and being too cold is almost as bad as being to hot , you get excessive wear in those conditions.
Old May 21, 2004 | 11:02 AM
Jay7 Nyc's Avatar
I bought Crooked Willow Oil coolers. Have yet to install them to see how they are..
Old May 21, 2004 | 11:55 AM
r71's Avatar
r71
If you are in anyways mechanically inclined, you can get 2 biggest oil coolers, thermostat, dual oil filter pedistal, mocal thermostat, fittings, and lines for under $1000.
Old May 23, 2004 | 10:59 AM
Droptopdsm's Avatar
Anybody else actually fitted and have results?
I would have thought oil cooler upgrades a common practice!?
Obviously not.
Old May 23, 2004 | 12:00 PM
Yes it is for sale.
A lot of people with touring and base models have upgraded to the dual setup. This is usually not the first coolant mod that people do though because of the costs associated.
I run CWR and have for two years.
Old May 23, 2004 | 01:24 PM
reza's Avatar
Agree with you.
During autocross, the car seems to have more power with oil in the 195 to a bit over 210F range.
Old May 23, 2004 | 01:35 PM
POM HB's Avatar
Lookie Only
How can rynberg change that? Another thermo that open later or close earlier?
Old May 24, 2004 | 10:24 PM
rynberg's Avatar
Simple. Put the black plastic cover back on over the passenger side oil cooler duct. I will definitely be doing this once summer is over anyway.
Anyway, my temp sensor is at the oil filter and represents the temps AFTER the oil coolers. The actual temp in the engine is hotter than 180F. I also seriously doubt that oil temps of ~180F are going to cause excessive wear, especially when using synthetic oil. In any case, it's a far cry better than running 220F.
Also, as I said in my earlier post, this kit is WAY overkill for the street. I bought the kit to reduce track day temps -- I'm tracking on this Friday, so I'll know how much of an improvement they are then.
Old May 25, 2004 | 12:33 AM
Zero R's Avatar
Just in time to die
200-210 is good on power you are correct, seems that is the sweet spot on most.
I also never said 180 degrees would cause excessive wear, I said being too cold would. Just throwing it out there.
If you were having a hard time keeping 180 then I'd worry.
Old May 25, 2004 | 02:48 AM
rynberg's Avatar
Actually, I AM having a hard time keeping it at 180F. The Mocal t-stat that comes with the kit opens at 80C (175F). It's been pretty much sitting there or slightly below. To be perfectly honest, I'd feel better if it was more like 190F all the time.
I think once the temps warm up a bit here, it's going to be fine, but for anyone installing this kit -- don't lose the passenger side inlet cover. I will be reinstalling it this fall to keep the temps a little higher.
Old May 25, 2004 | 04:23 AM
Jay7 Nyc's Avatar
Anyone know the part number for the passenger side inlet cover? I've never seen one and it gets pretty cold out here in NY..
Old May 25, 2004 | 06:46 AM
DamonB's Avatar
rynberg, what weight of oil are you running?
Old May 25, 2004 | 10:15 AM
rynberg's Avatar
10w30 Mobil 1
Old May 25, 2004 | 10:23 AM
rynberg's Avatar
cover -- FD01-51-3G5
clip -- GJ21-50-049
Old May 25, 2004 | 11:27 AM
CrispyRX7's Avatar
Polishing Fiend
http://www.negative-camber.org/crispyrx7/cwrcoolers.htm
HTH
My track oil temps now sit right around 210-220F IIRC which directly correlates with water temps. Previously 250+F. I have oil temp gauge sender mounted after oil coolers in oil filter pedestal.
Street driving oil temps are maintained at 180F constantly by the oil t-stat. Never higher. I run 10W30 Mobil 1
FWIW
Crispy
Old May 25, 2004 | 11:44 AM
rynberg's Avatar
THANKS CRISPY!
Your street temps make me feel much better! BTW, I actually got the car to hit 185F oil temps this morning getting on the freeway. Of course, they dropped to 175F in about 5-10 seconds after I hit cruising velocity....
Old May 25, 2004 | 02:35 PM
CrispyRX7's Avatar
Polishing Fiend
You will find that, if after driving the car at normal operating temps you come to a full stop, the oil temps will tend to climb a little to about 190-195 simply because the oil-tstat is already open and now the coolers have no airflow to draw the heat away. But as you observed one moving again, even if slowly, the temps drop immediately one airflow is resumed....at least that has been what I have seen.
Crispy
