Microtech question about microtech
Old May 18, 2004 | 10:41 PM
Matt22's Avatar
Fear The RE
so i dont know much about microtechs first and foremost. so here is my sererio. I am restoring a 72 mazda 808 coupe and putting in a rotary motor a 13b efi from a 88 gtu. and my car being a 72 i dont want to keep the stock wiring in the car. So with a microtech will that basically reaplace all the engine wires and do everything the engine will need.
Will i still need to and other drive train component?
Thanks matt22
Old May 19, 2004 | 10:15 PM
10sec rx7's Avatar
yes the microtech replaces all your stock wires,
you can remove everything apart from the wires to the starter and altinator
dale
Old May 19, 2004 | 10:53 PM
Matt22's Avatar
Fear The RE
ok so i could remove all wiring that deals with the engine. secondly how hard are they to install
thanks matt22
Old May 23, 2004 | 12:43 PM
silverrotor's Avatar
Generally, rewiring Is far easier. Mostly due to the lack of hearing crunch of the wires every so often, which can really slow down someone.
Old May 24, 2004 | 01:01 PM
fi addict's Avatar
here's a question to add...
lt12 vs ltx12
coilpacks needed on the "x" but why would one not want to uses the stock ones? and who has info on the lt12s? anyone on here get it in their car?
sorry to hop on your post but it should help both of us.
Old May 25, 2004 | 12:18 PM
Trav's Avatar
The Bosch coils would be needed in high HP applications. It's probably a debatable topic, but I think most people say beyond the 500hp is where you'll want different coils.
Stock coils are surprisingly capable -- I doubt most people would notice a difference in the sub 400hp area.
Old Jun 11, 2004 | 04:52 PM
JAKE1's Avatar
DONT THROW THE OLD HARNESS AWAY, YOU WILL NEED ALL THE PLUGS FOR THE INJECTORS, ECT.
Old Jun 18, 2004 | 09:15 AM
fi addict's Avatar
good tip JAKE1 lt12s on order
Old Jun 19, 2004 | 10:00 PM
Triangle Power's Avatar
Big Wankel
another reason for the "x" and running the bosch coils is you can run direct spark and not waste spark.
_Tones_
May 25, 2021 05:37 AM
freq
Haltech Forum
Sep 13, 2015 07:45 AM
Nosferatu
Sep 5, 2015 02:13 PM
