I feel like such a n00b.... :(
Old Nov 6, 2001 | 11:47 PM
adamlewis's Avatar
Back from teh deadly!
Whats the differences between 87-88 T2's and 89-91 T2's? Im talking mechanics...I know the tail lights are different, and they have different rims and stuff....But whats different drivetrain wise? Or power wise?
Old Nov 7, 2001 | 12:00 AM
JerryLH3's Avatar
Rabbit hole specialist
New twin scroll turbocharger
Higher compression
Lighter rotors
Those are a few mechanical differences that come to mind immediately.
Old Nov 7, 2001 | 12:01 AM
RestoTII's Avatar
89-91 have different turbo, I believe manifold as well.
They also have different rotors with slightly higher compression.
the 86-88 use a mechanical oiling system while the 89-91 have a different (electrical??) type.
The 89-91 are good for about 10% more power than the comparable 86-88.
Old Nov 7, 2001 | 12:03 AM
RestoTII's Avatar
Damn it Jerry.... I was trying to be the helpful one here and you had to go and sneak your post in before mine
At least we agreed with our explanations
Old Nov 7, 2001 | 12:15 AM
adamlewis's Avatar
So if Im going to go with a different turbo anyways, does it really matter which year I go with?
Old Nov 7, 2001 | 01:44 AM
FC Drifter's Avatar
Damaged Little F*cker
the 89 up uses an electrical oil metering system, has a twin-plunger tps, and a few other small differences. turbo wise the 89 up has a better turbo in that it is more efficient, runs more boost stock, a vastly improved wastegate design and a different manifold. internally the 89 up has lighter rotors, higher compression, and a higher max rpm(9000 vs. 8000). if you are talking about buying a 2nd gen, the 89 up is considered a better car because you have more power to start off with(202 instead of 180). the 89 up has a better motor in my opinion, but you can run more boost in an 87 because of its lower compression. the 87 is a lighter car by a small amount, but is virtually the same as the 89.
renjiv2
57
Jan 25, 2024 03:34 AM
Andrew7dg
Aug 6, 2017 01:41 PM
SSpyderX
1st Gen General Discussion
Sep 29, 2015 04:37 PM
