hi-flow cat & ecu
Old Nov 6, 2001 | 09:19 PM
Marcus's Avatar
hi-flow cat & ecu
WILL I HAVE ANY PROBLEMS IF I ADD A HI-FLOW CAT (N-TECH) TO THIS COMBO: INTAKE, CAT-BACK, DP, AND M2 STAGE 2 ECU? DOES THE HI-FLOW CAT BRING THAT MUCH TO THE TABLE WITH THIS COMBO? WILL I GET BOOST SPIKES OR LEAN CONDITIONS FROM ADDING THIS TO A STAGE 2 ECU? ANYONE RUNNING THIS COMBO? THANKS!
Old Nov 6, 2001 | 10:22 PM
JoeD's Avatar
youll be fine with a high flow.
turn your CAPS LOCK off.
Old Nov 6, 2001 | 10:36 PM
JoeD's Avatar
its not a good idea to run a midpipe with an M2 ECU...so ive heard.
ZacMan
Sep 19, 2015 09:20 PM
