Aftermarket Blow off Valves
Old Nov 6, 2001 | 07:11 PM
Jedon's Avatar
Slave2TheFD
Do you need a new BOV when going single? And if so, why and what considerations are there and how should it be mounted. Also, what is the best one to get (price consious...)
Thanx!
Old Nov 6, 2001 | 07:17 PM
RX-7 GT's Avatar
HyperREV.com
from what ive read: hks super sequential or the greddy type r. i think they're around the same price.
heard to stay away from: apexi, and the greddy type s
bov's are a must or something that everyone has, ive never seen a single without em. helps blow off excess pressure in the charge pipes between shifts. and prevent compressor surge. mounted closest to the tb.
Old Nov 6, 2001 | 07:30 PM
turbostreetfighter's Avatar
bov's
TIAL's are the best out there point blank!! no stupid adjustment and they dont bleed off like just about every other brand including Greddy and HKS, both of them will make you tighten down the screw until you basically make it non useable!! i think they retail for about 280.0 and they are a work of art
and yes you will need a bov especially if you are going to use a small shaft (t04 series ) turbo. or you will end up with a bent turbo shaft!
Old Nov 7, 2001 | 12:42 AM
AARotary's Avatar
Greddy Type-R or the HKS SSQV racing BOV. I am using the Greddy Type-R and it is mounted on the throttle side. Definitely stay away from the Greddy Type-S and the Apexi twin chamber BOV they sucks and they can hold higher boost applications.
Old Nov 7, 2001 | 02:05 AM
enzo250's Avatar
IRS Champion
Turbostreetfighter knows his ****... TIAL is the way to go when it comes to wastegate's and BOV's.. .There simply the best hands down.. Don't waste your money on H.K.S or Greddy.
Old Nov 7, 2001 | 06:37 AM
Greg's Avatar
The HKS (racing not SS) and the Greddy Type Rs are them best in my book. I havent seen too much of tial BOVs, maybe i will try one since turbostreetfighter is so enthusiastic
Old Nov 7, 2001 | 10:50 AM
enzo250's Avatar
IRS Champion
Don't say that H.k.s or Greddy are the best when you haven't seen the Tial.. You will change your opinion once you do...
And besides you have to buy the all out race model which is alot more expensive then the Tial Bov and they still can't outflow the Tial.. Go Figure..
Old Nov 7, 2001 | 12:02 PM
Greg's Avatar
any pics? links? specifications? or are you just saying that cause they sound cool? do you have one? The HKS racing and Greddy Type R are proven. Please provide some specs and info on the tial BOV.
Old Nov 7, 2001 | 12:27 PM
enzo250's Avatar
IRS Champion
Sure Greg:
Tial BOV Features:
  • The Body and all internal components are CNC-Machined from 6061 Aluminum Alloy
  • It Features a large 1.98" (50.3MM) valve; This is the largest valve available with the highest flow capacity.
  • The V-Band design aluminum mounting clamp gives a very clean and unique appearance.
  • The Clamp is anodized and uses Stainless Steel hardware for a long lasting , corrosion-free appearance.
  • The Valve Seal utilizes a Viton O-Ring (viton is an elastomer that is clamped in place to prevent the possibility of sticking to the seat and pulling out.
  • The Valve Stem and guide are Teflon-lubricated, hard anodize-coated for wear resistance.
  • The Actuator has a high temp silicone Nomex reinforced diaphragm for long life
my good friend is a dist. for Tial so i've been around them for quite a while now. You don't buy Tial Bov's because of the way the sound, Your buying quality...
Old Nov 7, 2001 | 12:29 PM
spyfish007's Avatar
Yellow Dragon is no more
Well since you did bring it up ... how does it sound?
Old Nov 7, 2001 | 12:34 PM
enzo250's Avatar
IRS Champion
They flow so well you don't hear them...
Old Nov 7, 2001 | 12:47 PM
the_glass_man's Avatar
Will u do me a kindness?
What about the Blitz? Where can I get the Tial BOV's? I've heard many a good thing about them.
Old Nov 7, 2001 | 01:14 PM
Greg's Avatar
OK,Ill keep my thoughts about which BOV I think is better. I will one day try out the Tial BOV. But for now I am gonna stick with the BOVs that are in the winners circle.
Old Nov 7, 2001 | 03:47 PM
enzo250's Avatar
IRS Champion
Monkey see monkey do... huh greg..
Thats not allow's the best way to go...
Anyhow if anyone is interested i can get tial bov's for 225ea.
Dollar for dollar you can't beat that
Old Nov 7, 2001 | 04:04 PM
Greg's Avatar
AHHH, now I see what its about, BTW the "proven" Type R Greddy BOV is only $200 at the rx7 store
Old Nov 7, 2001 | 04:09 PM
enzo250's Avatar
IRS Champion
Greg enjoy your greddy...
Old Nov 7, 2001 | 04:15 PM
maxcooper's Avatar
WWFSMD
I got a Tial for my car and it is very nice. You can definitely hear it, but I don't think it is as loud as the ones that were designed to be loud. It looks like it was just designed to work, which is what I was going for -- something that works.
I ran the car without a BOV for a little while, but it puts a lot of stress on the piping and connections. The RX6 turbo is said to be able to take the abuse, but why abuse it?
I got mine for $250 from Extreme Motorsports
Old Nov 7, 2001 | 04:43 PM
enzo250's Avatar
IRS Champion
Hey Maxcooper:
people who don't own one can talk all they want about their Greddy or H.k.s.
It's the people who actually own Tial who know whats up...
You couldn't of said it better, "It was just designed to work"
Old Nov 7, 2001 | 05:05 PM
gago's Avatar
when i bought my 93 touring fd it came with a single garrett t4/t3 and looks like the stock BOV in place close to the turbo.. now can i just buy this tial bov and replace the stock unit that i have with out changing the pipe?
any input is greatly appreciated:p
Old Nov 7, 2001 | 05:17 PM
Greg's Avatar
Hey Maxcooper:
Im not gonna turn this into a fight. I simply said that I have not played with the Tial and that I might try it. Calm your horsies. And, I have been enjoying my Type R with no complaints and so have ALOT of other people.
Old Nov 7, 2001 | 05:22 PM
enzo250's Avatar
IRS Champion
hey Greg...
I not looking for a fight.. But just trying to get you to open up your mind and take a look at some other products don't get caught up with all the Brand name junk like greddy, hks, etc...
Old Nov 7, 2001 | 06:46 PM
RX-7 GT's Avatar
HyperREV.com
tial is a brand name too, it must be junk it also makes little sound which besides helping with all that cool pressure stuff is the reason i like em
Old Nov 7, 2001 | 11:52 PM
sickboy's Avatar
dont forget the turbo XS unit. i dont think dollar for dollar that one can be beaten. 169$, very nice construction, and flows with the best of em. ive had a greddy and the blitz, and i like this one quite a bit better. ive always been impressed with the quality of Tial stuff, but dont have any experience with their BOV.
Old Nov 8, 2001 | 01:22 AM
Evil Aviator's Avatar
Rotorhead
Has anybody put an additional BOV in front of the throttle body to help keep the pressure wave from stressing the butterflies?
BTW, I have been considering Tial BOV for my 20B project. The quality looks excellent.
http://www.angelfire.com/me2/tpi/bovalve.html
Old Nov 8, 2001 | 04:04 AM
maxcooper's Avatar
WWFSMD
I'm not saying the GReddy and HKS aren't good, but just that the Tial is likely to be at least as good (probably better) and is cheaper. It is hard to arugue with top quality and performance at a lower price. And even then I am not *arguing* for the Tial over the others, just explaining what my motivation for purchase was.
The TurboXS is attractive for the same reasons, but I am not sure that its performace matches the Tial. Maybe it doesn't have to for many applications.
The GReddy would probably be best if you had to return the air to the intake, but the third gen has a speed density fuel injection system so you don't.
-Max
