question for tech heads
Old May 15, 2004 | 10:53 PM
AcidSlasher's Avatar
hey guys!
a bought me a series 2 rx7 12A with a bridgeport about a week ago. anyway the car has been running great, but i found a small tube in the engine bay that was severed, so i fixed it. anyway after i fixed it, the car ran crap, and wouldnt idle without the choke on. so i took away the fix to the tube and left it severed, and it runs great again. i was wondering if anyone could give me any insight to this? iv got a pic of the engine bay and the tube, id like to know what it does and what passes through it?? thanks
as you can see, there is a severed tube in the pic... it runs down to the bottom of the car somewhere to the right, and the left end goes to the carby, under the air filter (u cant see it)
thanks guys any input would be greatly appreciated!
Old May 15, 2004 | 10:58 PM
V8kilr's Avatar
DONT DRIVE YOUR CAR.
That tube is a line from your oil metering pump.
It supplies oil to the inside of your motor for lubrication.
Buy some new ones and fix the problem.
I have never heard of their being any differences in performance with them hooked up or disconnected though, was it possible that you plugged it into the wrong spot?
Old May 15, 2004 | 11:01 PM
357's Avatar
357
Stratoflattener
That tube is one of the lines for your oil metering pump (OMP). The OMP feeds a small amount of oil into the carb so that the apex seals and associated springs get lubricated. The oil then gets burned. If your engine isn't getting the proper amount of oil (which I assume it wouldn't be if that line is severed), it can overheat, and the apex seals will get fried. This outcome, of course, is sub-optimal.
When you fixed the tube, did you let the car warm up with the choke on? The choke should release itself (if its working properly) when the engine temp reached a sufficient level. If the engine still runs like crap with the hose fixed, and the engine hot, then I don't know what to tell you. But if the engine idles fine without the choke after its hot (with the tube fixed), then that basically stardard operation for a 12A.
RotaryRyan's Avatar
DSM
you can also do away witht the pump and premix 1oz per gallon
Do a search on "premix" if you want to do this.
Old May 15, 2004 | 11:47 PM
whoa crap, iv been driving it for a while like this. normally i drive to work every morning, takes about 35 mins, and with that pipe fixed it warms up as normal, but still wont idle without the choke... but without it it runs great???
and i didnt plug it into the wrong spot or anything, because the pipe is severed and i just stuck it back together... any ideas?? very confused :S
Old May 15, 2004 | 11:51 PM
RotaryRyan's Avatar
DSM
I think it was something else that made it run bad. I would ty it one more time. I really dont know what else to tell you
Old May 15, 2004 | 11:56 PM
just off the cuff could it be possible its getting too much oil or something? and consequently making the mixture off or something?
Old May 16, 2004 | 12:15 AM
where does this oil come from? does it come from the main oil sump? just wondering if theres another oil resevoir somewhere thats gonna run out of oil
Old May 16, 2004 | 12:27 AM
rxtasy3's Avatar
my question is, if it runs bad with it hooked up, where r u connecting it to? it doesn't go to a vac source. since there's only one tube, i assume ur running an aftermarket carb, stock carb has two tubes.
the oil comes from the pan, no extra resevoir(sp).
Old May 16, 2004 | 12:30 AM
if u look at the pic ul see there is another tube right next to it, its painted red so u mightnt have noticed it against the engine
Old May 16, 2004 | 12:47 AM
rxtasy3's Avatar
yeah i missed seeing it. the one that's cut connects right next to the other one.
Old May 16, 2004 | 01:47 AM
hey guys i re-fixed the tube and now it seems to run fine... so i dunno what happened last time but i took someones advice and tried again now it runs great! thanks for all the help guys
_Tones_
May 25, 2021 05:37 AM
ZacMan
Sep 19, 2015 09:20 PM
Nosferatu
Sep 5, 2015 02:13 PM
