Clutch Master Cylindar Upgrade?
Old May 13, 2004 | 01:21 AM
Hey guys, where can IO find a bigger clutch master cylindar? Mine is going out, so I thought I would get a little bit bigger one to lessen the problems of getting it into gear easily. Do you guys have any part numbers or places I could go for one? Thanks!
Old May 13, 2004 | 03:14 AM
AdrenalifeRX7's Avatar
Are you gonna shift?!
I doubt you would need a "bigger" clutch master cyl. The stock ones work fine for a variety of applications.
Old May 13, 2004 | 10:10 AM
mazdaverx713b's Avatar
Have RX-7, will restore
there is nothing really. the stock ones hold up well and work fine. have you tried bleeding your clutch and replacing the fliud?
Old May 13, 2004 | 12:06 PM
MarkPerez's Avatar
Tennis, anyone
No body makes an 'upgrade' depending on the model you have,, s, gs, gsl, i've found that the gsl-se clutch master to be a bit better then the others, but really there all the same. me, i like a firm pedal and since there are no adjustments what i do is add an 'inner'
stiffer spring to the stock spring and that seems to work
well.
Old May 15, 2004 | 12:19 AM
jhillyer's Avatar
Re: Clutch Master Cylindar Upgrade?
Almost any master cylinder can be retrofit. A larger one will result in a firmer pedal and less pedal travel before the clutch (dis)engages.
Old May 15, 2004 | 12:45 AM
red_blast's Avatar
S.F.W.C. Liberator
all you need to do is replace the clutch master and slave cylinders as well as the line and you will be golden. Give VB a call.
what are you going to use???? i have and would never try another vehicle's cms. i understand the concept but how would this help you out?
The1Sun
Sep 15, 2015 04:45 PM
