changing from 12at carb to injection??? advice plz.
Old May 8, 2004 | 02:03 AM
ilmunkee's Avatar
Newbie
hey guyz need sum info n advice on my 12at 45mm dellorto side draft set-up..
had the engine in a 79rx7 til i pulled it out n sold it bout two months ago.. wanted to pull apart the block n learn bout the engine i got n hopefully chuck on an injection system off a 12at 626 cozmo(computer n loom etc...).
been reading heapz bout the seals n stuff off this site n learning qwik as this is my first tym owning a RE n dnt think ill ever go bak to piston xcept 4my *******..
wen i had it on the road waz boosting 6psi n output of bout 175hp in the rear but leaning out in 3rd gear coz of the restrixion in gas from the carby which is y i want 2 go injected..
ne ideas on what 2do n how2 start my project would b much appreciated here in new zealand...
cheerz guys. ILTANG..
Old May 8, 2004 | 05:18 PM
Sponge Bob Square Pants's Avatar
ne ideas on how 2typ so wee can reed it?
just giving you a hard time, but seriously, I don't even really understand what your question is.
I'm assuming from the title you want info on coverting a carburated 12a to fuel injected, but in the post you ask for info on your carburated setup you already have.
If you are going FI, you want to do it righ the first time. Stand alone engine management system. That alone will set you back $1000, not to mention all the other components needed (complete fuel system, manifolds, the list goes; on an on).
I haven't done this before, because I haven't needed to, but I speculate this could run you a few thousand dollars fairly easily.
You'd be better off to buy a complete 13BT (second generation RX-7 turbo engine) longblock and swap that in. It would cost less and you'd end up with a far better engine in the end.
Old May 8, 2004 | 06:24 PM
ilmunkee's Avatar
Newbie
thanx 4 your input n pleaz excuse my typing.. im a newbee with the computer aswell as rotors so people are just going to hav ta tolerate my **** 4 a bit...
cheers though, im now considering the 13bt set-up n might hav to sell my 12at set-up to get started... what do you reckon..series 4 or 5 n whats the difference between the both????
ill keep reading n post up with questions
Old May 8, 2004 | 06:51 PM
Check out the 2nd Generation forum on this site, and go into the FAQ area. There you can find out the differences between S4 and S5 cars. Generally the S5 is a more desirable engine - it has better porting, a slightly better turbo, and the main benefit of upgraded engine internals.
Don't disregard the S4 engine though, unless you are planning something crazy, it will serve you just as good. If you want decent power you would replace hte turbocharger anyway, and porting the engine more than makes up for that difference. These S4 engines are perfectly fine when rebuilt with all stock components to safetly run at mid-high power levels (like 400 whp)
Thanks for joining the forum by the way! There's a search function in the top right corner. Being a few years old and having over 40,000 members, most questions can be answered by using that search. Don't be afraid to post if you can't find your asnwers though!
Also check out the 1st generation forum to see what else can be done with your current 12A setup if you are not quite ready to swap in the 13BT yet. I don't know a lot about 12A engines but the guys there are very helpfull.
The1Sun
Sep 15, 2015 04:45 PM
risingsunroof82
Sep 7, 2015 01:11 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
