MoTeC Area is for discussing the MoTeC EMS.
MoTeC Will Motec controll the OMP?
Old May 7, 2004 | 10:57 AM
sillbeer's Avatar
I'm sure it will but I maybe wrong. I was just wondering. Is it a pia to wire up? I have a new harness with all new sensors with my m8. I recently bought a 20b fc with an m8 in it also but the omp isn't wired up. Not to fond of pre mixing the gas but I will if it's necessary. Will a 3-D water injection solenoid work wired up to the omp? Thanks.
-Destin
Old May 8, 2004 | 09:35 AM
RETed's Avatar
To my knowledge MoTeC doesn't.
Maybe you can bug the MoTeC programmers to change this - it has enough outputs to do this no problem.
-Ted
Old May 9, 2004 | 11:58 AM
OzFeTt's Avatar
is the omp a variable voltage input? If so, no the motec can't control it. Motec has only duty cycle and switched outputs, no variable voltage.
Old May 9, 2004 | 12:53 PM
j9fd3s's Avatar
Community Builder
its a stepper motor
Old May 9, 2004 | 02:19 PM
onefastrx7turbo's Avatar
Merovingeon
Veteran: Air Force
According to the motec manual, it can control a stepping motor. isnt the omp a stepper motor? it looks to have 4 stages, 1-4. maybe we can make this work sillbeer..
neil
Old May 10, 2004 | 07:41 AM
sillbeer's Avatar
Just maybe it can work. But I have dibs on the stock harness. Asashka was telling me between pan speed, amemeya, and some other big rotary tuner shops they all have there different thoughts on weather the omp or premix is better. hmmm. Clipping Point was saying premix is better. Who knows?
Old May 10, 2004 | 12:07 PM
Merovingeon
Veteran: Air Force
Yea, some people have that same debate here too. it involves whether mixing the gas into the oil protects the apex seal tips well enough. also, I guess people say that under pressure, IE high boost, the boost pressure in the housing can prevent oil from being put out by the oil injectors. But, maybe both is better? just go a little less on the premix? I dunno. I might not need the connector. I have a S5 and an FD harness with OMP connectors. maybe one of them is the same...hmm
20B Forum
21
Mar 22, 2022 01:00 PM
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
