Surging at cruising in 4th and 5th...
Old May 4, 2004 | 09:16 PM
Kenteth's Avatar
Like Ghandi with a gun
So I've noticed this waaaay back when, when we still had the autobox pos tranny. Back then it would surge at cruising. It was nothing massive, but definately noticeable... It feels like the car loses power for a a quarter second, and then surges when it gets that power back. It does this on/off surging for about ten seconds, to where i get tic'd and downshift WOT...
So after teh 5spd swap, I figured the problem was gone... A couple weeks after driving it around...
its baaack..
Last night I was crusing at around 50 in the hills and it just did it again. Loss of power, than back, then loss again. I don't know what it is. It feels like a mild event of the car having not enough power for the gear/rpm.
Only thing is, im at a fine rpm for crusing at the time it happens...
Any ideas?
Old May 4, 2004 | 09:26 PM
BlackRx7's Avatar
Daily Domestic Killer
Have you tried reseting the TPS this is usally the main cause of surging, I had very minor surging in my TII in 4th but the new alt fixed that problem
Old May 4, 2004 | 09:27 PM
Kenteth's Avatar
Yeah, we set the TPS and timing before I went on a roadtrip to nebraska about a month ago... Didn't seem to surge on that trip though... might be somethign to look at again
Old May 4, 2004 | 09:45 PM
Roy James's Avatar
My cars louder than yours
check for vac leak, and check your MAP. when it surges does it go away with acceleration?
Old May 4, 2004 | 09:51 PM
Kenteth's Avatar
it doesnt go away with putting the throttle down, downshifting well into the power band is usually the wuickest way to save it
Old May 4, 2004 | 10:02 PM
WAYNE88N/A's Avatar
slightly broken internal contacts on the water thermo sensor plug- caused by being hit by that BS harness standoff on the alternator lower bolt nut- only seperate when the engine's warm & you're just cruising along, and then only for a second or two- that's my guess (can ya tell it's happened to me too?)
Old May 4, 2004 | 10:52 PM
BlackRx7's Avatar
please elaborate Wayne
Old May 4, 2004 | 10:56 PM
WAYNE88N/A's Avatar
green plug on the sensor behind the alternator- check it out for cracks and abnormal play- like I said, just a guess...
Old May 4, 2004 | 11:16 PM
Kenteth's Avatar
Wayne, does the ECU retard the advanced timing based off of this? I know the plug you're speaking of, and its a little bastard IIRC... Green square with a japanese snapping paperclip around it?
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
LongDuck
Oct 7, 2015 08:12 PM
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
